Author Topic: HOW TO: Create an IRC channel using mIRC  (Read 78500 times)
Offline CranK_Max
  • [CranK] Max
« on: November 11, 2009, 01:27:26 pm »
How to create your own mIRC channel ?
First open up mIRC and identify yourself. (You need a registered nickname in order to register a channel)
Choose a name for your channel and join that channel.
(/join #channelname)
Then type :
/cs register [#channelname] [password] [short description]
Now you registered your channel, and you are registered as it's owner. Like this:
If you didn't automatically receive  the "~" in front of your name, just type the following commands:
/cs identify [#channelname] [channelpassword]
and
/cs owner
If you want a bot for your channel type /bs botlist and choose a Botname.
Then do /bs assign [#channelname] [Botname you have choosen] to assign the specified Bot to your channel.
After that you have your channel with a bot! :)
If you want to set someone on a higher position like "+" or "%" do :
/cs [look down to my description] [#your channel name ] [add] [name of the user]
To delete it just replace "add" with "del".
To perform more commands on players do /cs help you'll find a list with help topics.
* description:
"vop" = +  (voice rights:   you'll still be able to talk when the channel is muted)
"hop" = % (halfop rights: like a moderator, kicking and muting is in your power)
"aop" = @ (op rights:       lika an admin, banning and several other controls are at your disposal)
"sop" = &  (higher admin: some more stuff you can do)
If you want your own topic without any extra colours just do that:
Double click in the red marked field.
A new window pops up. Now you can write your own topic in the again red marked field:
To use colors in your topic or in your chat text use ctrl+k to pop up the colors window.
To use underline, bold etc fonts, the same shortcuts as in Microsoft Word apply. (ctrl+B, ctrl+U, ctrl+S, etc..)
So thats all, you have your own channel now.
Greez Max  :)
[topic updated on spelling/syntax by Faraday]
« Last Edit: May 26, 2010, 12:43:33 pm by Mike Litoris »
I had to laugh xD
Re: How to create a mIRC channel
« Reply #1 on: November 11, 2009, 06:19:52 pm »
It's pretty good tutorial, I think will help many people.
« Reply #2 on: November 11, 2009, 06:51:50 pm »
Nice work there CranK_Max!
Offline iShine
  • Flyin'
« Reply #3 on: November 11, 2009, 07:00:06 pm »
Good work!
Offline j.king
« Reply #4 on: November 12, 2009, 12:31:46 am »
nicely done :)
Offline Bugsy
    • Champions of Steel
« Reply #5 on: November 12, 2009, 12:34:39 am »
Good work man!
Blood...Runs...Cold
Offline Neonkiller
  • Got Milk?
« Reply #6 on: November 12, 2009, 02:52:24 am »
Sticky! GJ m8 that should help a lot of players out.
« Reply #7 on: November 12, 2009, 02:59:05 am »
nice nice nice thanks :)
« Reply #8 on: November 12, 2009, 04:10:42 am »
like wallie will/would say..
cool story bro
Offline CranK_Max
  • [CranK] Max
« Reply #9 on: November 12, 2009, 01:03:35 pm »
Ty all  :)
First time I did something usefull :)
Thank you guys
I had to laugh xD
« Reply #10 on: November 12, 2009, 02:22:40 pm »
Good job, nicely done!  ;D
Offline iShine
  • Flyin'
« Reply #11 on: November 14, 2009, 04:17:45 pm »
But you can't add commands into your channel ?
Offline CranK_Max
  • [CranK] Max
« Reply #12 on: November 14, 2009, 04:26:31 pm »
You can,
Like on #lw.samp. eg.: "?away"
I had to laugh xD
« Reply #13 on: November 14, 2009, 05:10:01 pm »
You can,
Shine , talk to Ez  :)
Offline iShine
  • Flyin'
« Reply #14 on: November 14, 2009, 05:12:32 pm »
You can,
Yes, I know, but Ez isn't online. I think he sleeps.
