Author Topic: the slam builder contest  (Read 48695 times)
Offline elbrujo
« on: April 05, 2008, 12:41:48 pm »
A certain Mr.Xshit have a great idea! we can construct a race with several builders! so if you have an idea, you can post it on this topic!  ::)
Offline elbrujo
Re: the slam builder contest
« Reply #1 on: April 05, 2008, 01:05:44 pm »
so i start with my 3  last races. if someone have an idea about the start of THE-jumper,.... i build it differently but it's a shit :o. i give you the testing blog's result:
-- THE-jumper --
- except the name, start is the same confusing + reverse thing, fix it (Knuckles)
- I love it, except fix the confusing start (raz0)
- other than the start it's perfect (Knuckles)
- bad start just add another cp or 2 (Plop) ( ok plop, but where!!  :P)
- cp27 ramp needs moving foward :O (Plop)
- What's bad about the start is: I am led straight into the fence. (raz0)
- having to turn around on the 1st cp will make people run face-to-face with you (Knuckles)
- rest of the race is perfect. (Knuckles)
- fix the start and its a keeper (Cygnus)
Voted yes: 0 / Voted no: 4
* Map deleted * :-*
for THE-jumper2, i have a drug trip, so you can use it, destroy it,.... the start is a cluster at the 1st turn, & many players talk about a laggy(?) (damn english)  map
for )^_^)pogo, the point is the mines in this map, but if you have ideas you have total liberty!
the testing map's result:
-- fuckingham-DM1 --
- dont think that this will work (Cygnus)
+ full of cool ways to die (Plop)
- there should be hunter pickups around the sea (Plop)
- add more dangerous spots , and change the name (Knuckles) :-X
Voted yes: 0 / Voted no: 3
* Map deleted *
you can change all the map, just a part,....
« Last Edit: April 12, 2008, 02:48:56 pm by elbrujo »
« Reply #2 on: April 05, 2008, 02:38:50 pm »
Erm... now what's the point of this here? You give us 3 maps and we'll have a contest of who made the best solution or map??? Why don't we use one map at a time and than vote for it? Lot easier to determine which is best and people only have to put time in one map to fix it...:)
[Edit]Brujo, I suggest you pick one map for redesigning/repairing/building and have a nomination later :)[/Edit]
« Last Edit: April 05, 2008, 02:40:24 pm by Snipe »
Offline elbrujo
« Reply #3 on: April 05, 2008, 03:24:59 pm »
oh the contest is just for the topic's title :P
the point is to proposing a map ( an entire, just a start or a piece of the race) & the others build on it if they want. in fact it's a cooperation.
for example, mr.dogshit post a piece of a map. you or me watch it and build on it if we have an idea. we repost it and discuss about it, etc...... it's an exchange to make a multibuilder map.
ps: i post my maps because i've no idea how i can finish it, so if you have an idea.....
ps2: i think under1 or under2 is a good idea plop so if you want to propose it on this topic, it will be nice i think
« Reply #4 on: April 07, 2008, 02:28:00 pm »
Still, i suggest one map at a time, since you want to discuss about it's improvements/changes... If we all approve the map after some cycles of repairs/changes we can move on to the next map that need some fixing/changes... agreed?
[Edit]Point out a map and will gladly help... if i have some time, i have to fix other maps for Cygnus as well[/Edit]
« Last Edit: April 07, 2008, 02:31:34 pm by Snipe »
Offline elbrujo
« Reply #5 on: April 07, 2008, 06:52:56 pm »
it's not necessary a map. you can have just an idea or a piece of a map and someone take his turn to continue it. we can discuss (or not) about it after.
for me the real point is to build an entire map with many builders. we can build a piece and someone continue it
« Reply #6 on: April 07, 2008, 07:08:03 pm »
Okay... but wouldnt it be fun just to start with one of your maps??? Let's say we start with The_Jumper1 and you give it to, let's say, mr.Dogshit... and than mr.D gives it to me, so i can add some of my touch to it... and... as a result... the author of map should be called... Mr. D.E.B.S. :P... so mapname would be: The_Jumper1_By_Mr.DEBS! :D
Offline MCvarial
« Reply #7 on: April 07, 2008, 07:16:27 pm »
that would be better just with a better name XD
« Reply #8 on: April 09, 2008, 01:21:23 pm »
I think you should pick a map Brujo and hand it over to me (meaning, upload it here just like you did with those other 3 maps)... and than i'll post/upload it later on with my adjustments :)
Offline elbrujo
« Reply #9 on: April 09, 2008, 06:46:21 pm »
aaaaaaaaaaaaaaaaaaah snipe
this is exactly the point of this topic!!! héhé
ps:plop! can we use under and would you want to post it or can i do it??? ???
« Reply #10 on: April 09, 2008, 09:51:57 pm »
lol, i always knew what your up about... it's just the concept of using one map at a time which i pointed out all the time you didnt get... either way: i want to join :P
Offline mr.dogshit
« Reply #11 on: April 11, 2008, 12:49:08 am »
Hey guys  ;D
I promised Brujo i'd post  ;)
anyway, im in of course... it'd be good if we could get a few more people involved too.
Offline Plop
« Reply #12 on: April 11, 2008, 06:37:41 am »
np you can post it brujo
Offline elbrujo
« Reply #13 on: April 12, 2008, 02:47:59 pm »
thanks plop
so i post the 2 "maps" of holy plop. it could be a good start so download it & post your impression or your build!
« Reply #14 on: April 15, 2008, 08:42:40 am »
I don't like both versions, how do i know for example that players will rise up at the 2nd map. I keep getting stuck when i'm testing it. Also, the first one is also under the ground. I don't like that, i always build above the ground, since there are more possibilities and more space...
