Author Topic: Ping issues.  (Read 14101 times)
Offline Abnormal
Ping issues.
« on: February 19, 2010, 07:24:11 am »
Basically my ping has started jumping from its usual 160'ish ping, into the 200's, 300's, 400's, etc
It only spikes for a second and goes back into the 100s for about another second, and then it will spike, and it has been doing this ever since I installed windows 7.
I had downloaded a windowed mode mod, that I installed and I used it, and when i was using it, my ping never jumped. It stayed in my normal 160 range, 140-160
However I noticed that I only get 45 fps while I am in windowed mode, opposed to my 80 while I am in fullscreen. So I switched back. And as soon as I switched back, my ping started spiking again.
Virus? Spyware?
I've already scanned with Avira, and search and destroy, and nothing was found.
Re: Ping issues.
« Reply #1 on: February 19, 2010, 07:41:54 am »
if it is caused by some program which is slowing your internet without asking then you could find it with netlimiter (google it and download the "Pro" version) and kill/block the process foreveeeer.
btw since 0.3 you dont need mods for window mode. you can just use alt+enter to jump to window mode whenever you want.
Offline Abnormal
Re: Ping issues.
« Reply #2 on: February 19, 2010, 08:01:43 am »
thx, going to try it out
Offline Roy_Melee
Re: Ping issues.
« Reply #3 on: February 19, 2010, 11:44:12 am »
are you using dial up or something? you warp like shit in the server.
Re: Ping issues.
« Reply #4 on: February 19, 2010, 01:25:42 pm »
taskman + common sense
Re: Ping issues.
« Reply #5 on: February 19, 2010, 02:27:13 pm »
Dail up lol, is there actually a LW regular who still uses that shit?
And @ Abnormal, 45 is quite a perfect fps-rate, since with a fps rate above 47/48 you cant strafe with the deagle..maybe its fixed in 0.3 but it was like this in 0.2x
Offline [JOKER]Ya$N
Re: Ping issues.
« Reply #6 on: February 19, 2010, 02:30:30 pm »
I have a friend has the same problem
Stunt video || Click
Offline Abnormal
Re: Ping issues.
« Reply #7 on: February 19, 2010, 04:12:41 pm »
I don't warp. Warps effect both players, and I haven't noticed anybody warping. So my question to you is, who the fuck are you and why are you in my thread?
Re: Ping issues.
« Reply #8 on: February 19, 2010, 04:42:18 pm »
I dont think they fixed it cuz Im having troubles with strafing right now (but it's not impossible)
Re: Ping issues.
« Reply #9 on: February 20, 2010, 03:19:05 pm »
DIAL UP RULEZ!
Scott still uses it! lol
And a sheep or two will sort out all problems
Re: Ping issues.
« Reply #10 on: February 20, 2010, 03:34:37 pm »
DIAL UP RULEZ!
wat
Offline [JOKER]Ya$N
Re: Ping issues.
« Reply #11 on: February 20, 2010, 04:40:37 pm »
Offline Abnormal
Re: Ping issues.
« Reply #13 on: February 20, 2010, 07:40:15 pm »
That beat isn't bad.
Re: Ping issues.
« Reply #14 on: February 22, 2010, 10:55:57 am »
stop smartassing around, rizla
even you can see the different, can you?
explain me with your ultra admin common sence if my RTHDCPL.EXE process is right now slowing me internettttttttttttttt, WILL YOU?????????????????????
« Last Edit: February 22, 2010, 11:28:56 am by BikeDriver »
