Poll
Lower the bank limit?
To 1million and 2million for donators
15 (50%)
Leave it the way it is
13 (43.3%)
Lower than 6million and 8million for donators, but higher than 1million
2 (6.7%)
Total Members Voted: 30
Author Topic: Lowering bank limit  (Read 21643 times)
Offline Chainer
Re: Lowering bank limit
« Reply #15 on: May 26, 2010, 05:10:58 am »
I can see this going one of two ways:
- It'll make the competition more fun as you have to work more for your money, OR
- It'll make regulars join less because every time one plays would require a pretty big time investment in getting money, etc. People won't bother joining for short amounts of time because it just isn't worth spending valuable money on guns for only 30 minutes of play.
ankit
« Reply #16 on: May 26, 2010, 05:45:44 am »
The idea is good. But at present LW we have on one there is neagtive feature in bank i.e. when anyone has negative balance, it is deducted from their bank account. And now on other hand we will have only 1 min bank limit. So, in my view let the limit of bank go down, but atleast remove negative feature of bank or set it to '0'.
« Reply #17 on: May 26, 2010, 07:36:21 am »
good point but..
well, in my opinion, the maximum anyone will spend on weapons is 300k? Which is one third of their bank account(if this is implemented) and they rarely run out of ammo in one life, they will eventually die and spawn back with full ammo. So why don't they just spend less money on weapons(around 100k?) if they're going to play for a short period of time? And by that time I'm pretty sure they will get more than what they've spent on weapons, it's easy for the regulars to make cash on LWs.
« Reply #18 on: May 26, 2010, 08:52:46 am »
+1 , will be a real fight for properties.
« Reply #19 on: May 26, 2010, 10:30:27 am »
That was changed a month ago, and the bank balance doesnt go negative anymore.
Offline wannabe
« Reply #20 on: May 26, 2010, 10:33:32 am »
-1 it should be that you are atleast able to buy like "hop hop hop" from the special shop! and that you also are able to buy atleast some properties with the money you have in bank!
« Reply #21 on: May 26, 2010, 10:35:47 am »
Chainer has a valid point, changing it to 1million all of a sudden might cause regulars to leave. Maybe a progressive change has more benefactors.
Offline CranK_Max
  • [CranK] Max
« Reply #22 on: May 26, 2010, 11:21:23 am »
It HAS BEEN limited a few moths or half a year ago. Its good like it is
I had to laugh xD
« Reply #23 on: May 26, 2010, 11:23:30 am »
This sounds allright, but i prefer Miczi's idea for now.
EDIT: I voted bringing the balance back to 1 and 2 Million.
« Last Edit: May 26, 2010, 11:35:52 am by S3rs »
Offline Alex0
« Reply #24 on: May 26, 2010, 11:54:58 am »
Nice idea, because for example things like the ''hop hop'' cost like 1,5 mill, that's means that you can buy this very little if the maximun is only 8mill, then is better change the bank limit,
« Reply #25 on: May 26, 2010, 12:38:20 pm »
Voted for 1 and 2 million. It makes ppl work harder!
« Reply #26 on: May 26, 2010, 12:52:44 pm »
1 million is good
« Reply #27 on: May 26, 2010, 01:33:00 pm »
They don't have to die to refill weps, they can take a rampage and do /stoprampage, it gives u all your spawn weapons.
If my idea would not get accepted I would like to lower the bank limit as much as it is possible, better this than nothing :P
Offline Roach
« Reply #28 on: May 26, 2010, 05:09:17 pm »
I do not think some donators will agree with this, some people donated for things like a bigger bank account, and now you guys want to lower it >again< ?
Damn, good thing i never have donated, cause i would feel screwed with changes like this.
So I would say, keep the max 8 mill for the donators!
maybe it sounds stupid for alot of you guys.
but since lw is filled with stupid players you might take away a goal to play on for some players, because they just like having alot of cash.
I personally don't really care about cash itself.
I care more about making races with it, bounties i like to set every single player, and
I liked playing with hidden blip until they have removed it, now there is nothing much special & useful things to buy.
So maybe lower the amount for non donators to 3 million would be a good idea...(at least not lower than 3.)
 and try to create a few extra special fun items that are really wanted at the city planning.(sorry i can't come up with anything right now :D except for putting hidden blip back & also that it works outside a vehicle so i can snipe the shit out of people ;D.)
You can always go lower or higher again if it doesnt work out.
« Reply #29 on: May 26, 2010, 05:12:00 pm »
That's a bug that Slice should fix.
