Author Topic: Is there an unlag patch?  (Read 22399 times)
Re: Is there an unlag patch?
« Reply #30 on: November 07, 2010, 06:41:47 pm »
Try this: http://download.gta-expert.it/gta-san-andreas/patch-fix/172-antisabbia.html
it doesn't change any texture and it works ;) u won't see anymore the dust effect
Instructions are in italian, but i translate them here:
Installation:
Replace the file "effects.fpx" in the "GTA San Andreas\models\" folder.
« Last Edit: November 07, 2010, 06:45:19 pm by Quickplay »
Offline j.king
« Reply #31 on: November 08, 2010, 12:15:12 am »
what is this?
its an edited effects.fpx file.
« Reply #32 on: November 10, 2010, 12:37:14 pm »
a brand new PC wont help. the dust particle effects cause lags. same with the clouds. its either a bug or a compatibility problem.
i tested it with different (high end) video cards, quad and single core CPUs, different OS's, different RAM's different resolutions etc.
im quite sure it lags on your pc too if you shoot into desert sand.
Offline Swanson
« Reply #33 on: November 10, 2010, 12:54:30 pm »
This problem doesn't occur on every computer. For example on my laptop it works great (AMD Turion x2 2.0GHz), but on my pc (Core2Quad q8300 2.5GHz) it's a big issue. Even though my pc has a better CPU and graphics card, the problem exists. I'm sure Benny doesn't have this problem on his pc, otherwise he would've known it has nothing to do with just having a good pc (which he has, but probably he's lucky).
« Reply #34 on: November 10, 2010, 02:17:40 pm »
I got a decent computer and it doesn't lag anything.
Offline Swanson
« Reply #35 on: November 10, 2010, 03:49:15 pm »
Read what Bikedriver said, it's either a bug or compatibilty problem. Personally the compatibility problem sounds more plausible to me.
Offline Marius
« Reply #36 on: November 27, 2010, 12:03:41 pm »
   It's the GPU (Graphic Processing Unit) that causes this, not bugs.
Certain GPU's and drivers react differently when rendering the dust or other particle effects.
Who says this is a bug, or even considers it as such ... just proves that he's, ahh ... nevermind.
« Last Edit: November 27, 2010, 02:23:48 pm by Darin Nethar »
« Reply #37 on: November 27, 2010, 03:34:45 pm »
and for this completly useless (and wrong) smartass post you bumped a weeks old thread?
« Last Edit: November 27, 2010, 03:37:03 pm by BikeDriver »
Offline Marius
« Reply #38 on: November 27, 2010, 09:42:15 pm »
Go and preach your evolution vectors to someone who actually cares.
