Author Topic: SA:MP Scripting References  (Read 34183 times)
Offline Simon
  • Retired
  • SA-MP: [CP]Simon
« on: November 06, 2010, 05:02:25 am »
You can feel free to post any references below.
« Last Edit: November 06, 2010, 05:16:19 am by Hazard »
Re: SA:MP Scripting References
« Reply #1 on: November 06, 2010, 03:10:48 pm »
Understanding the SA-MP sync.
A tutorial on basic SA-MP client-server communication. Also available in spanish.
« Reply #2 on: November 06, 2010, 03:58:32 pm »
MySQL Tutorial for beginners.
Very basic mysql tutorial which teaches you how to connect to, send and receive information from a mysql database.
Offline Slide
« Reply #3 on: August 16, 2011, 10:38:47 pm »
Want to make your own first Game Mode?
Really basic, but very helpful.
Click me for link
This should get you starting.
Have fun and good luck!
and sorry for huge bump :x
« Last Edit: August 16, 2011, 10:43:05 pm by Slide »
Offline Matz
« Reply #4 on: August 17, 2011, 05:06:57 pm »
And there are Map Editing stuffs available.
SA-MP Map Editor
MTA-SA Client (recommended)
« Reply #5 on: August 19, 2011, 01:22:47 am »
One question with the mta:editor if you make a map what do you do to convert it to samp and how do you put it in your gamemode?
Offline Slide
« Reply #6 on: August 19, 2011, 01:31:55 am »
use www.convertffs.com for converting.
and then open .pwn file (whatever your script iz called, exmp: Virus.pwn) and then add Objects under  OnGameModeInit()
« Reply #7 on: August 19, 2011, 04:58:13 am »
Yes , but if you use 0.3c Objects , convertffs doesnt work fine , will convert another objects.
I use an application >> http://solidfiles.com/d/301d9/
Offline Matz
« Reply #8 on: August 19, 2011, 11:17:16 am »
Tiny info: There's a question from FAQs. "When I put biggest maps in my gamemode, some objects disappears?". Because SA-MP has a limit of object (I guess 400 Objects). When you are exceed the limit, some objects gonna be disappeared. So can use Streamers for fix these.
An example: http://forum.sa-mp.com/showthread.php?t=102865
« Reply #9 on: August 19, 2011, 03:50:52 pm »
Thanks both of you but were can i find the file that i need to convert in the mta program files shiz
Edit:The solidfiles download doesnt work with my pc :(
« Reply #10 on: August 19, 2011, 06:17:59 pm »
i'll try to upload  on another website
.map file can be founded in
C:\Program Files\MTA San Andreas\server\mods\deathmatch\resources
« Reply #11 on: August 19, 2011, 07:27:10 pm »
thanks :D
the download works i think its cuz its 64bit :x
Offline [RMS]Yakuza
  • Pawno Scripting
    • SoG
« Reply #12 on: March 26, 2013, 07:41:02 pm »
Good Work =D
Offline Slide
« Reply #13 on: March 26, 2013, 07:48:15 pm »
