Author Topic: Need Help? Ask it here!  (Read 215829 times)
Re: Need Help? Ask it here!
« Reply #15 on: November 13, 2010, 09:28:36 am »
I remember KmanN sending me a duel-filterscript once, was the same as Nx server a while back.
« Reply #16 on: November 13, 2010, 11:41:05 am »
Okay, nvm.
I made a duelscript.
« Reply #17 on: November 13, 2010, 12:00:19 pm »
« Reply #18 on: November 13, 2010, 12:09:54 pm »
Nah. :)
« Reply #19 on: November 14, 2010, 05:47:47 pm »
I made that..! Btw if anyone still has the Nx server source, pls give! I wanna see how much i failed at scripting back then.
@Simon.: Your script is probably so great, you have to keep it for yourself. I'm guessing nobody ever made anything like it!
« Reply #20 on: November 15, 2010, 07:45:03 am »
not really, good enough tho :)
« Reply #21 on: November 15, 2010, 12:37:35 pm »
who's the boss? he's the boss.
« Reply #22 on: November 15, 2010, 03:39:24 pm »
Exactly 8)
« Reply #23 on: November 16, 2010, 01:25:47 am »
only if you ask nicely for it slice.
« Reply #24 on: November 16, 2010, 08:52:06 am »
pweeeeeeease
« Reply #25 on: November 16, 2010, 09:46:44 pm »
Offline [Cheetos]
« Reply #26 on: November 21, 2010, 08:17:30 pm »
can u explain us how to make christmas tree?!<<<< iz noob men :(
« Reply #27 on: November 22, 2010, 11:02:11 am »
MTA 1.0
Best map editor ^
« Reply #28 on: November 26, 2010, 10:18:37 pm »
HALP!
public OnFilterScriptInit()
     CreatePickup(1240, 2, -551.6004, 2609.5679, 66.8359, 0);
     CreatePickup(1242, 2, -551.6616, 2607.9106, 66.8359, 0);
     return 1;
What I wanted it to do: Create a health and armor pickup and respawn after sometime it was picked up.
What it did:The armor respawns fine but the health doesn't(first CreatePickup).
So what is wrong? Do I need another return value? And yes, I'm a noob at this and im just starting to learn it.
« Last Edit: November 26, 2010, 10:50:12 pm by NiGHTM4RE »
Offline Simon
  • Retired
  • SA-MP: [CP]Simon
« Reply #29 on: November 26, 2010, 10:53:49 pm »
It seems to be related to this SA:MP bug, just create a dummy pickup before your other ones.
     // This will not be able to be picked up by normal players.
     CreatePickup(1253, 0, -133333.7, -133333.7, -133333.7, -1);
     // All your pickups from here onwards
     CreatePickup(1240, 2, -551.6004,2609.5679,66.8359, 0);
     return 1;
If that still doesn't solve it, then try using the pickup types 15 and 22. They have the same effect as type 2, if it still fails then you may have to script the pickup to respawn.
