Author Topic: All Points Bulletin anyone?  (Read 89902 times)
Re: All Points Bulletin anyone?
« Reply #150 on: May 28, 2011, 05:48:03 pm »
Meh..Im crashing all the time. I do 1 or 2 missions and iz ova! :'(
Need to get 2GB RAM moar!!!
So is this game free to play already or what ?
Yesh iz free! Register and download and pley! ;)
Sneaky
« Reply #151 on: May 28, 2011, 05:56:30 pm »
@Faraday try disabling VOIP in-game, then restart your game and goto task manager, and kill the vivoxvoiceservice process - should help somewhat, there has been a lot of issue's with the in-game voip system, it's terrible :C
« Reply #152 on: May 28, 2011, 09:24:18 pm »
ok thanks, I'll try that. Do I have to kill the voip process everytime I play?
Sneaky
« Reply #153 on: May 28, 2011, 10:22:33 pm »
Yeah :(
« Reply #154 on: May 29, 2011, 07:53:46 pm »
It also helps killing the process APB_Gecko.exe, not sure what it's used for but it takes a whole less CPU memory.
« Reply #155 on: May 29, 2011, 11:08:39 pm »
Ive tryed this tutorial, and not sure if it boosted my FPS, or not but it should have.
Copied from APB site: How to up your framerate with config file mod
Alright, basically I have a computer that is basically near the minimum recommended specs for APB and I did a little tweaking to try and make it run better. Now I''m getting about double the FPS that I did before (from 20ish to 40ish) and I figured I would post this to help others in similar predicaments.
Editing the settings
1. Go to your APB programs file folder. For me, it''s in C:\\Program Files\\Realtime Worlds\\APB North America (Mine is in steamapps>commonfiles) Nasty
2. Click on the APBGame folder, then on the Config folder
3. Now click on the APBCompat.ini file and open it with notepad. If it''s read-only, right click on properties and uncheck the box
4. Go to file, save-as and save this file as a backup on your desktop
5. Ctrl-F and search for "BucketX" where X is the graphics slider that you use in-game. 1 being minimal, 2 being low, and so on. I''d imagine that most of you already running on minimal settings though. If you''re still running on high, I''d suggest turning down your graphics slider in game and seeing if that increases your fps. In other words search for bucket.. set stuff to false and make sure options are set to minimal in game (nasty)
6. Set the following values:
DynamicShadows=False
BlobShadows=False
LightEnvironmentShadows=False
MotionBlur=False
DepthOfField=False
AmbientOcclusion=False
Bloom=False
QualityBloom=False
Distortion=False
DropParticleDistortion=True
MaxDynamicShadows=0
bEnableVSMShadows=False
bEnableBranchingPCFShadows=False
bAllowBetterModulatedShadows=False
bEnableForegroundShadowsOnWorld=False
Basically, we''re turning off all of the flashy shadows and bloom effects in order to bump up your fps.
Disclaimer
Make these changes at your own risk, it may lead to game instability/crashes. In my experience though, I have been running way smoother than before and have yet to experience a crash (even though my computer is utter shit compared to many of your rigs).
Thanks for reading.
Addendum:
You''re going to have to start APB without the launcher in order to keep your changes. To do so, go back to your APB program files folder, click on the Binaries folder and then click on the APB application in that folder. I would recommend creating a shortcut to this file on your desktop.
Hope this helps people with bad fps issues..
« Reply #156 on: May 30, 2011, 12:11:26 am »
Ah yes yes! Thx for the infos Jetson! I did it and it helped with fps(not that I rly needed it)
Ill do some few moar tests with it and see whats best! x)
« Reply #157 on: June 02, 2011, 06:56:11 pm »
SMACK!
Anyone knows how to avoid "Queue" ?? ..like with buying something or? Or thats just have to be like it is? I wait 30+ mins to join. :-[
« Reply #158 on: June 02, 2011, 07:12:25 pm »
u guys got a clan or gang goin or something ?
« Reply #159 on: June 02, 2011, 08:45:27 pm »
I don't really get the friends system. Is there a way to see if anyone is online?
« Reply #160 on: June 02, 2011, 10:04:21 pm »
I heard theres some "/pop" thing D:
Never used gang-clan-friend thing tho. I just jump in there push the K button and get raped! x)
tbh noone wanted to help me here
Sneaky
« Reply #161 on: June 03, 2011, 07:31:04 am »
@Faraday you just add people as friends, and you'll see the coming online and offline.
@665 You can't avoid the queue, unless you're premium, there is some network problems where after a certain amount of players are online it starts lagging really badly, a queue has been put in place to prevent that from happening, hopefully they will fix this soon.
/pop it the amount of players online in that world.
For more updates keep checking http://apbreloaded.gamersfirst.com/ - they explain the whole queue thing here too.
« Reply #162 on: June 03, 2011, 10:09:33 am »
Can someone make like a tutorial on how to install and get an account, Basicly a tutorial to get it up and running. Cuz it seems shady and dodgy to me right now..
« Reply #163 on: June 03, 2011, 10:55:15 am »
Press U, Faraday!
Sneaky
« Reply #164 on: June 03, 2011, 10:59:23 am »
@WildStyleZx89 http://www.gamersfirst.com/apb/
They brought out a new patch like an hour ago, which adds constant GPF crashes ;D
