Author Topic: Mapping question  (Read 3793 times)
Mapping question
« on: March 05, 2011, 01:46:12 pm »
Simple question: How many objects can a mapping projects (for example a christmas tree) have on a server like littlewhitey's without any problems?
Re: Mapping question
« Reply #1 on: March 05, 2011, 05:57:12 pm »
Well, the max was 256 objects but I think it is more now because of the newer versions of SA-MP. But hey, you could also just use a streamer, and then you can use as much objects as you want to.
« Reply #2 on: March 05, 2011, 09:04:27 pm »
I didnt know streamer allows to use unlimited objects. The problem is that I don't really know how a "streamer" works.
« Reply #3 on: March 06, 2011, 12:58:47 pm »
They're not hard to use.
Here is a streamer:
http://forum.sa-mp.com/showthread.php?t=117920&highlight=object+streamer
Just follow the instructions and you should be fine. You can convert the map file from MTA or a sa-mp script to the right format by using http://www.convertffs.com/ . Just change the output ''sa-mp createobject'' to Fallouts object streamer (if you are going to use the streamer that I posted)
