Author Topic: Video card problem  (Read 18426 times)
Video card problem
« on: June 05, 2011, 08:52:15 pm »
For some reasons I don't know why my video card isn't working properly.
In GTA I see the shadows different , also the sea is green (lol).Today I was trying to play a game and it didn't want to start , I was searching if my PC can handle the game , all's ok , but it doesn't recognize the video card.
I have ASUS AH3450 Series , 512MB.
Any ideas?
Re: Video card problem
« Reply #1 on: June 06, 2011, 02:24:15 am »
did you pick 16 bit color depth?
use 32 bit..
« Reply #2 on: June 06, 2011, 06:11:09 am »
use 32 bit..
I use 32bit.
« Reply #3 on: June 06, 2011, 06:45:39 am »
I heard that Windows 7 x86 dont allow unsigned drivers,so I guess youre using x86 and your drivers are not signed by 7...
I also heard that chip is made by ATI and if ASUS dont have up-to-date drivers then youll need some of these .. :o
« Reply #4 on: June 06, 2011, 07:28:55 am »
use 32 bit..
I use 32bit.
did you pick 32 bit ingame too?
« Reply #5 on: June 06, 2011, 10:21:44 am »
I do have Windows XP.
Right now I turned to 16bit and it works fine for a game which doesn't work at 32bit.
« Reply #6 on: June 06, 2011, 11:11:14 am »
lol I just said what I heard about what might be problem with your video card.. :P
So now you play on 16 and everything is oke? D:
Damn u piratebays!!! Ruining ppls PCs since.. 84? x)
« Reply #7 on: June 06, 2011, 11:10:47 pm »
how about just updating all of your drivers? See if that works.
« Reply #8 on: June 20, 2011, 08:06:49 pm »
I updated graphics card drivers , same as before.
* Forgive pokes BikeDriver
« Reply #9 on: June 20, 2011, 09:01:20 pm »
i can only say the same thing again:
what resolution did you pick ingame?
you should select something like 1280x768x32, the 32 means 32 bit color depth.
be sure that it says 32 :P
also download the latest version of DirectX
if that doesnt work then your probably screwed because you need a new graphics card.
« Reply #10 on: June 20, 2011, 09:12:36 pm »
I reinstalled it and seems it works pretty good.
In-game resolution is 1024x768x16
« Reply #11 on: June 20, 2011, 09:59:28 pm »
you retard!!!!!!!! pick x32
use arrow keys and search for 1024x768x32, confirm with ENTER key
« Reply #12 on: June 21, 2011, 07:49:42 am »
I'll do that , seems it works quite fine right now , I reinstalled the driver.
« Reply #13 on: June 21, 2011, 08:48:01 pm »
oh i am too late to help
but that is good cause you already fixed it. I had the same problem 2x or 3 times from 2006 till 2010, it allways helped to reinstall the drivers.
but i had a nvidia card
« Reply #14 on: June 21, 2011, 09:51:09 pm »
Good to hear you got the problem solved. Most of the solutions have been said (update driver, reinstall game, reinstall drivers, change resolution, etc)
However, i did research the card and came across this in the description:
- Gigantic 512MB memory on board
Made me lol (no offence Forgive)
