Author Topic: Samp or gta doesnt work?  (Read 18102 times)
Offline SKY
  • Quad Buddy
« on: September 10, 2011, 02:07:36 am »
Okay so i decided to play samp and i found out gta didnt load. I kept clicking connect thinking i was lagging. I re installed samp thinking it would solve my problem, but it didn't. Single player dosn't work either. Any one know how i can fix this?
« Last Edit: September 10, 2011, 02:19:33 am by SKY »
Since 2008
Re: Samp or gta doesnt work?
« Reply #1 on: September 10, 2011, 06:58:46 am »
Sounds like a weird problem.
I'd suggest reinstall it all. sa-mp, gta itself, and if nothing helps the OS.
Btw have you tried restarting your PC and then tried again?
Or checked if the process of gta_sa.exe opens?
What OS do you have?
What exactly happens when you try to connect, or open single player?
Did you perform any changes of the OS lately?
Faye
« Reply #2 on: September 10, 2011, 08:17:16 am »
This probably will work:
Goto Documents >> GTA San Andreas User Files >> then delete gta_sa.set, then try joining again, I'm sure it will work
« Reply #3 on: September 10, 2011, 10:23:57 am »
Faye is right, this should work.
Offline SKY
  • Quad Buddy
« Reply #4 on: September 10, 2011, 02:04:27 pm »
k will try thanks :D
Since 2008
Offline SKY
  • Quad Buddy
« Reply #5 on: September 10, 2011, 02:34:05 pm »
Doesnt work my os is windows vista, and when i try to connect it just loadings with a green circle and then stops :\.
Since 2008
Offline SKY
  • Quad Buddy
« Reply #6 on: September 10, 2011, 02:49:07 pm »
well it works when i run as administrator.
Since 2008
Offline Gryphus_One
  • Personal Text
    • My Youtube account ;)
« Reply #7 on: September 10, 2011, 06:54:49 pm »
Windows Vista is shit, but I guess neither Samp nor GTA itself should need administrator privileges to run, as I for example use both from a limited user account in my Windows XP. Have you switched to Vista recently, or have you been using it for some time before having this problem?
« Reply #8 on: September 10, 2011, 07:16:14 pm »
Well if it runs in admin mode - run it in admin mode :P
Offline SKY
  • Quad Buddy
« Reply #9 on: September 10, 2011, 09:56:13 pm »
the admin mode is my brothers account and the settings on it it shit, i used another user to play samp but now its saying things like this and its crashing before it loads.
Since 2008
« Reply #10 on: September 10, 2011, 11:16:55 pm »
:O looks like a deleted shortcut to me.
anyways is this a 64bit OS?
Offline Gryphus_One
  • Personal Text
« Reply #11 on: September 11, 2011, 12:50:15 am »
Well if it runs on one of the Windows' accounts while on the other it doesn't, then it might be a problem with your user files as someone has said before.
Offline SKY
  • Quad Buddy
« Reply #12 on: September 11, 2011, 01:13:14 pm »
yea probably, well what i did atm is make a new user file where i can move the files there and play. Im still gonig to find out how i can fix it because i know this problem might come.
Since 2008
« Reply #13 on: September 11, 2011, 08:50:01 pm »
Is it my shitty sight or you have installed san andreas on desktop?
« Reply #14 on: September 12, 2011, 06:39:49 am »
SAMP AND GTA DONT WORK
