Author Topic: The Agreement  (Read 24185 times)
The Agreement
« on: October 16, 2012, 06:32:26 pm »
This is a short brace of the Agreement's original topic, look for it >>here<<.
This topic has the only purpose to summarize the rules each Guardian clan has to follow, and to stand as place for questions regarding the Agreement.
All Guardian clans are automatically signed to the Agreement and have to follow it's rules.
THE AGREEMENT - RULES:
1st: For each two clans online with more then three online members, these clans must split in different clan gangs and fight.
2nd: Therefore, in each clan gang must not be more then two members from other clans, and if they are they must be the only two online from that clan.
3rd: These rules imply, that whenever there are three members of a clan online, they have to create and join a clan gang.
4th: Two clans can agree on ceasefiring although being three or more members online per clan, only if there are no other three clan members online.
5th: The Agreement does not intend to create enemies. We strongly encourage every clan member to see the fights as fair competition, not as devious attacks.
6th: The Agreement's rules also involve non-Guardian clans in so far, that Guardian clans are not allowed to team on non-Guardian clans.
The Agreement violations evidences - guidelines
§1: Agreement violations - definitions
  • Gang organization violation:
    A gang organization violation is given when the following events occur:
    1: There are more than 3 members of two clans in one gang
    2: There are more than 3 members of two clans online, and at least one member of one clan is in a gang with at least one member of the other clan.
  • Teaming violation:
    A teaming violation is given in case of the following events:
    Prerequisite: In the following cases is assumed that all involved clans are online with more than 3 members and no gang organization violation occurs.
    1: Two members of different clans attack a third member of a third clan at the same time without attacking each other after this third member's death although in direct firing range.
    2: Two clans stay in direct firing range without attacking each other.
    Exception: If only two clans are online, they can agree on a truce.
    3: While two clans are fighting a third clan is roaming out of range without attacking.
§2: Agreement violations - formal requirements for evidences
  • Gang organization violation evidences
    Evidences have to be brought in the form of two screenshots, where the ingame SA time is visible and /timestamp is activated. Beetween the times the screenshots were taken there must be a delay of at least five minutes. The /gang info of the involved gangs has to be visible on both screenshots. Use /gangs to retrieve the gang ID of the particular gang. In case 2: give also two screenshots of the score board (TAB).
  • Teaming violation evidences
    In every case the evidence has to be a video. Make sure the quality is good enough so that names are visible.
    In case 1: give a video where the violation is clearly visible. If you yourself are attacked keep recording even after you died. Provide a short clip of the complete scoreboard to make sure all prerequisites are fulfilled.
    In case 2: give a video where is clearly visible the two clans or clan members are in direct line of sight without at least one of them firing. Also provide a short clip of the scoreboard.
    In case 3: use a fast car or helicopter/plane to follow the roaming clan. Start the video at the position of the actual fighting clan and drive/fly towards the roaming clan. Make sure it is visible that the clan shows no intentions to rush towards the other clans. The clip should at least be five minutes long.
    Do not in any case postprocess the videos with any kind of effects, text or music. Do not cut the clips if possible, provide as much information as you can get.
« Last Edit: November 11, 2012, 06:37:43 pm by EnzoMortelli »
Re: The Agreement
« Reply #1 on: November 11, 2012, 06:40:31 pm »
Agreement rule addition
We added rules for the evidences for Agreement violations now. Every player who sees such a violation can report it here, by giving the needed evidence in the correct format as described below.
Offline SKY
  • Quad Buddy
Re: The Agreement
« Reply #2 on: February 20, 2013, 12:32:54 am »
I object.
Since 2008
Re: The Agreement
« Reply #3 on: February 20, 2013, 10:01:48 am »
Actually, new rules and rule changes/additions within the Guardians have always a one week trial period, where any Guardian member can object against it when providing an actual reason to do so. If you as a clan member have an objection against a rule, speak to your clan leader first, as he's the one that represents your clan within the Guardians, so he can object against the rule change on your behalf within the one week period.
« Last Edit: February 20, 2013, 10:11:42 am by EnzoMortelli »
