Author Topic: Windows 7 ping problem  (Read 15257 times)
Re: Windows 7 ping problem
« Reply #15 on: December 23, 2012, 07:33:29 pm »
Check your background processes and close anything not necessary, that may help.
Offline Huggy
  • Was a proud LW player
« Reply #16 on: December 24, 2012, 12:47:38 am »
a fin abnadem bsa7a l pc jdid,
ur problem is that u have low wireless signal as i already saw last months or so, try to get good signal or use cable ( if ur situation still the same as i know, it possible to use long range cable )
maybe back.
Offline ZheFoxy
« Reply #17 on: December 24, 2012, 07:48:35 am »
lay3tek ssha. a fine rake tb9a tji l xfire
« Reply #18 on: December 24, 2012, 12:20:06 pm »
löknas ölkjtnölkhn sdlkhnsöletnhjölkiha söfkjihswöreljkhjölj waserlöokijöwlrknaghnmfks.,ldng-l., nzlö-k.inh tog!?!?!
 ;D
Offline Huggy
« Reply #19 on: December 24, 2012, 12:47:10 pm »
 ;D
sry i dont speak russian  ;D
maybe back.
« Reply #20 on: December 26, 2012, 02:57:09 pm »
Ok
Reinstall your network / motherboard drivers.
Those are usually the problem.
Also i dont have xfire i find it useless.
Offline ZheFoxy
« Reply #21 on: December 26, 2012, 08:38:50 pm »
idk its Win 7 or any of the drivers  i guess its my internet problem some times i can play some times not idk why.
« Reply #22 on: December 26, 2012, 09:02:36 pm »
With drivers i mean install the driver files for your network card (piece of hardware inside ur pc) and the drivers for your motherboard.
Sometimes when drivers are not installed the network card goes to a default or lowest possible setting. And since this is a new windows 7 installation its highly likely that this is the case.
Can you tell us the make and model number of your PC ? You can find those numbers on the back or bottom of your PC. (Do not give us your Windows validation key though that would be bad if you did)
And if you build the PC yourself tell us the Motherboard modeltype. And then ill find the correct drivers for you.
