Author Topic: weird problem  (Read 5685 times)
Offline bikerRR1000
weird problem
« on: August 15, 2014, 10:15:24 pm »
hello guys i have a weird problem when im trying to connect to server it puts me in the single game S.A. reinstalled gta sa and sa-mp but still the same problem...
Re: weird problem
« Reply #1 on: August 15, 2014, 10:32:08 pm »
Reinstall samp!
Offline bikerRR1000
Re: weird problem
« Reply #2 on: August 15, 2014, 10:33:03 pm »
did it but nothing
Re: weird problem
« Reply #3 on: August 15, 2014, 10:41:52 pm »
Hmm... only do this steps
right click on samp.exe
then properties compatibility
then (run this program as an administrator)
if you are using windows 7 (run this program in compatibility mode for (windows xp "service pack 3")
apply then ok
If this work tell me :D
« Last Edit: August 15, 2014, 10:52:00 pm by PlaYaz »
Offline bikerRR1000
Re: weird problem
« Reply #4 on: August 15, 2014, 10:58:24 pm »
apply then ok
i dont know how those steps could help me. my problem is when i try to connect to the server it puts me in the single game san andreas......
Re: weird problem
« Reply #5 on: August 15, 2014, 11:45:21 pm »
apply then ok
I dunno then
Wait till our Programming team answer (enkei, BikeDriv, Enzomortelli)
« Last Edit: August 16, 2014, 12:15:56 am by PlaYaz »
Re: weird problem
« Reply #6 on: August 21, 2014, 06:03:52 pm »
Eh,did you patch gta samp file? You must do that when installing samp....
Im a bit inactive nowadays,so i may reply a bit late.....
« Last Edit: August 21, 2014, 06:06:02 pm by Runizor »
Re: weird problem
« Reply #7 on: August 28, 2014, 10:12:39 pm »
A bit late, but maybe you still need it. Have you tried deleting the GTA_SA.set file? It's in My documents -> GTA: SA.
Delete it and try to run the game then. It helps with many common problems.
About the compatibility mode and admin, that's the first thing I should do when I have a problem with a program. Try this on samp.exe and also on GTA:SA.exe (or however the singleplayer file is called).
You can also take a look here (but I guess you already have): http://forum.sa-mp.com/showthread.php?s=be3d1d528567e9155fec4c2f15a455e5&t=326298&page=2
Re: weird problem
« Reply #8 on: August 29, 2014, 12:05:55 am »
Even later, but you might wanna check two things:
1: Do you have the right version of GTA (v1.0/downgrader patch) installed?
2: Settings in the SA-MP client window: Is your SA directory set to the exact directory this SA-MP client is installed in?
