Author Topic: Error: cannot find 800x600x32 video mode?  (Read 48002 times)
Re: Error: cannot find 800x600x32 video mode?
« Reply #15 on: September 19, 2014, 01:21:19 pm »
there is no target in dis? maybe if you have skype we could do this.
You can chat via IRC,playa(less waste of ur time + much easier)
Since ezno gave you an explanation,i guess my job is done here...... :D
« Reply #16 on: September 19, 2014, 05:32:11 pm »
Create Shortcut
right click shortcut, choose properties
see the first field with the file path n shit ("Ziel")
do this to it. (obv with your current resolution)
click dis.
double clik shortcat
set resolushun in game menu
close game
delete shortcat
play semp.
« Reply #17 on: September 19, 2014, 08:43:13 pm »
after doing this still same proplem :(
can you send me this text? because when i try it it no work :(
Offline iDamn
  • I'll be damned!
    • Find me on Steam!
  • SA-MP: iDamn
« Reply #18 on: September 20, 2014, 05:23:52 am »
Pretty sure it's just..
-width=1080 -height=640
What's sad is I can't set my resolution to 1360x720 in single player. Maximum on 1280x768. Works fine on sa-mp though.
« Last Edit: September 20, 2014, 05:28:10 am by iDamn »
« Reply #19 on: September 20, 2014, 09:21:08 am »
@idman: google is your friend: 'Display Settings Extender'
@playazzz: try deleting your gta_sa.set from le user files and then try the stuff from above posts. If this all doesnt help:
-Find a friend/classmate/alternative self with a computer that runs gta.
-Run gta there.
-Set resolution to desired value ingame.
-Close game.
-Copy gta_sa.set from frinds userfiles.
-Paste into your user files.
-Profit.
(Also, you may wanna update your graphics card drivers)
« Last Edit: September 20, 2014, 09:22:42 am by EnzoMortelli »
« Reply #20 on: September 20, 2014, 10:39:53 am »
i got it from my another laptop, but when trying open semp dat wat i can see
and i tried to delete gta_set file i got the
its my luck its messed up :(
« Reply #21 on: September 20, 2014, 12:05:27 pm »
Try to update your MSVC++ library, you can find the newest versions on Microsoft's sites somewhere.
Also update your graphics card driver, then run gta_sa as admin, in compatibility mode winXP.
Also give it a try to start it via elevated command line to try that resolution trick again:
Click Start, search for 'cmd', right click cmd.exe, choose 'run as administrator',
navigate to your gta_sa.exe file
cd <insert path here> and run it with options:
gta_sa.exe -width=1024 -height=768
If this all doesn't work delete everything and reinstall gta from your very first original source (CD/DVD/copy), then try again.
Offline Lofty
« Reply #22 on: September 20, 2014, 03:38:19 pm »
Have you thought that maybe your monitor doesn't display 800x600x32 ? I recommend you check that first
« Reply #23 on: October 02, 2014, 06:53:58 am »
Not working on windows 8!!
« Reply #24 on: October 02, 2014, 10:04:00 am »
Where the hell did windows 9 go?
Offline AnonLiv2
  • SA-MP: Bleck
« Reply #25 on: March 05, 2016, 06:23:10 pm »
I am not a member of your community and neither do I play your server .
I had the same problem and was googling and finally landed here !
The only reason which I am replying is because of you (EnzoMortelli) , Sir .
Your reply certainly made me laugh . A LOT .
Thanks for that .
Peace !
Offline AnonLiv2
  • SA-MP: Bleck
« Reply #26 on: March 06, 2016, 08:25:10 am »
Hello .
If someone is still suffering from this problem , Here's a simple but effective fix !
Firstly , on the desktop , Right click and choose "Graphic Properties" (There will be an Intel icon near it) So click on Graphic properties that has Intel icon near it .
Next , Click on "Display" tab . Click on "Custom Resolutions" .
There will be a warning . Just continue by pressing "Yes" .
Under "Add" tab , Enter the following .
In width box : 800
In height box : 600
In refresh rate box : 60
That's all you need to do . Just click "Add" button located in the bottom right corner and add it . Close the graphic properties .
Open GTA Sanandreas and Enjoy :) :) . Thank me later :)
(Note , you can change the resolution in > Settings > Display Settings > Advanced Display Settings > Resolution)
