Author Topic: Help regarding TOTAL OVERDOSE  (Read 8915 times)
Offline KaMRaN
« on: September 24, 2014, 03:44:38 pm »
I've installed Total Overdose (A gunlisher's tale in Mexico). But when I start game, my LCD's screen turns black and give me following message "Optimum Resolution 1280x720 not supported". I've checked all the requirements and drivers of PC but still it's not working for me! I can hear all the sounds in back but can't see the video.
Here are my PC specifications:
Graphic Details :
My PC's specifications are high enough to run the game smoothly. But it's not giving video output.
Re: Help regarding TOTAL OVERDOSE
« Reply #1 on: September 24, 2014, 04:02:15 pm »
Seems the resolution of the game is set to something your monitor does not support. Try starting the game with commandline parameters '-width=800 -height=600'.
Offline KaMRaN
« Reply #2 on: September 24, 2014, 04:09:50 pm »
Commandline text is not working for this game.. Any other method please!
Offline Burntillusion
« Reply #3 on: September 24, 2014, 04:18:37 pm »
RIP PC
Offline KaMRaN
« Reply #4 on: September 24, 2014, 04:23:31 pm »
Haven't you check those specifications?
« Reply #5 on: September 24, 2014, 08:04:51 pm »
Locate and delete the settings file if possible. Then try again.
Offline KaMRaN
« Reply #6 on: September 25, 2014, 09:04:12 am »
Which settings?
« Reply #7 on: September 25, 2014, 10:04:57 am »
Some games store your settings (like display resolution and keymaps) in an seperate file on your hardrive, e.g. GTA San Andreas saves the file gta_sa.set in the userfiles. If your game does this you can locate that settings file (google is your friend) and then delete it. The game will automatically recreate a new file when it starts next.
Alternatively, you can try the command line parameters on a link to the game exe. For that make a new link to the game exe and add the forementioned parameters to the target path of the link rather then the exe itself.
If both doesn't work it might be worth a try if the game supports windowed mode, start it up and press Alt+Enter to switch to windowed.
