Author Topic: Everytime I lose the connection  (Read 17259 times)
« on: January 31, 2015, 02:39:16 pm »
Allright here we go.
My problem starts like that. Whenever I shutdown/start my laptop everything is fine. After 15-20 mins I lose a internet. I'm with a laptop as I said:
Lenovo Z510.
So what I've to do. I've tryed to troubleshot the problem but doesn't work.
If I want to fix my problem with the net I've to do these steps:
Control Panel -> View network status and tasks -> Change adapter settings -> then I've first to Disable my Wireless Network Connection and then to enable it. This works for between 30-40 minutes.
Re: Everytime I lose the connection
« Reply #1 on: January 31, 2015, 02:43:56 pm »
Happened to me too, but it was ISP's fault (Internet Service Provider).
But if you have laptop, probably its wireless's fault. Try to directly connect to cable.
« Reply #2 on: January 31, 2015, 02:46:04 pm »
Well if I use the cable my laptop becames a pc. I've bought a router and don't want using a cable.
Thanks anyways, PawnFox.
« Reply #3 on: January 31, 2015, 02:48:24 pm »
I understand you don't want to use cable, but doing what i said you will know where is the problem. Or is the ISP or router.
« Reply #4 on: January 31, 2015, 02:50:08 pm »
try to change or update the wireless driver, should work.
« Reply #5 on: January 31, 2015, 02:51:38 pm »
I've used the cable with my laptop and everything is fine. All comes from my wi-fi/wirreless. Tryed to change the drivers but still doesn't work.
« Reply #6 on: January 31, 2015, 03:58:22 pm »
So your router/modem doesn't lose the connection right? It's just your laptop losing the connection?
I'm asking cause i had a similar problem till few days ago, but it was my modem acting up, and it turned out i just had to fill again the router's infos
« Reply #7 on: January 31, 2015, 04:33:48 pm »
same, because i think it is windows 8.1 problem, because in before in windows 7 i didnt had the problem, after i bought windows 8.1 it began to lose the connection which is annoying..
i hope i'd know how to fix it
« Reply #8 on: January 31, 2015, 04:56:30 pm »
QP: yeah only my laptop lose connection.
Playa: I'm using windows 7 and maybe all comes from the windows.
Offline Falk3n
« Reply #9 on: January 31, 2015, 06:05:00 pm »
It's not the windows, Freak. We both are using the same windows and I don't have this problem...
« Reply #10 on: January 31, 2015, 06:20:47 pm »
I know that all comes from my laptop. But I don't know how to fix this shit.
« Reply #11 on: January 31, 2015, 08:16:19 pm »
You tried to update network driver ?. If doesn't work then i suggest you trying to reinstall windows .
Then its router fault, if cable work properly. Buy a new one.
« Last Edit: January 31, 2015, 08:27:21 pm by PawnFox »
« Reply #12 on: January 31, 2015, 08:34:40 pm »
I'm gonna try to reinstall the windows, yeh!
« Last Edit: January 31, 2015, 11:16:29 pm by [Freak] »
Offline Falk3n
« Reply #13 on: January 31, 2015, 11:00:53 pm »
I'm gonna try to uninstall the windows, yeh!
You mean reinstall :D Hope it's gonna work, maybe something went bad when we installed the windows :/ Good luck facker.
« Reply #14 on: January 31, 2015, 11:18:35 pm »
Control Panel -> View network status and tasks -> Change adapter settings -> Right Click the connection that represents your Wifi -> Status -> Details
Find the entry 'IPv4 standard gateway', that should be the private IP of your router inside your home network. Copy that ip into your browser and open it. The control panel of your router should show up (in most cases). First check if all the settings there are correct.
Second, many router control panels show a connection status and if not connected error messages. Check what it says when your connection times out.
Another thing: Search for the device manager in Control Panel -> Hardware and Sound and open it. Find your wifi adaptor and right click it, choose Properties. Find the tab energy management, and untick the box 'computer can turn off this device to safe energy'.
All i can think of atm, hope this helps.
