Author Topic: SA:MP help!!! 5m ingame reward!  (Read 23000 times)
Offline Naoufal
Re: SA:MP help!!! 5m ingame reward!
« Reply #15 on: August 20, 2015, 08:48:14 pm »
Reinstall GTA SA, SP and SA:MP.
How do i reinstall it when i pirated it?
Redownload or just copy n paste it to a new place and reinstall SAMP to it?
Ty
Search for a new pirated version?
For some reason i think i need to install something on laptop, when i had original Windows it worked fine, as soon as i wiped it with a different Windows, then reverted back to Win 8, it seems like somethings missing, i installed DirectX and all that shit, lemme look for another pirated version
try restarting your pc
._____________________________________________________.
* Zeus. looks at playa
Wait, i'll upload the pirated iso file for you, gimme a couple of mins.
Huracan
« Reply #16 on: August 20, 2015, 08:48:57 pm »
Ty
Do i need to burn the ISO or can i extract it with Winrar?
ty
Theres also an application called, trainer.exe i've heard that trainer = cheat? :o never used it lmao
S0n1c
« Reply #17 on: August 20, 2015, 08:49:46 pm »
you gotta ask EpicHunter, he is the computer genius....
Offline Naoufal
« Reply #18 on: August 20, 2015, 08:51:40 pm »
Ty
ty
You need to burn it, i think that you can't get cheats through applications.
EDIT: You should download the pirated version by your own, my internet is slow to upload.
Huracan
« Reply #19 on: August 20, 2015, 08:56:04 pm »
Ty
ty
I tried many versions men, any softwares, that i should install? I used the same GTA SA all this time since 8 months :3
« Reply #20 on: August 20, 2015, 09:04:22 pm »
lol! run trainer.exe for a laugh
Huracan
« Reply #21 on: August 20, 2015, 09:07:15 pm »
I did open it, nothing happened though, what is it meant to do?
« Reply #22 on: August 20, 2015, 09:39:46 pm »
How did you revert from win10 to win7 and then further to win8?
Huracan
« Reply #23 on: August 20, 2015, 10:05:15 pm »
Bad life decisions, bad life decisions, now i have this problem
Cannot find video mode 800x600x32
"Your resolution is being a bitch" ~ Aryan
Huracan
« Reply #24 on: August 20, 2015, 10:18:01 pm »
it's important to know because if you just installed the OS above the other over and over then it's not the same as a clean installation after formating the hard drive.
Also please be sure that the copy of san andreas you have it's working properly, otherwise you'd be wasting your time finding the problem somewhere else than then game itself. What i mean is: install your san andreas in another pc and see if it works.
Nah i formatted the disks when i switched OS, also, i used to use this for 8 months, redownloaded it and another one, both don't work
« Reply #25 on: August 20, 2015, 11:03:26 pm »
How do you start the SA-MP serverbrowser? Klicking a taskbar/desktop shortcut or by navigating into GTA's folder and starting it there?
Huracan
« Reply #26 on: August 20, 2015, 11:29:56 pm »
Well, my sa directory is in My Downloads, clicky clicky, open the folder SAMP, *opens* voila!
« Reply #27 on: August 20, 2015, 11:48:01 pm »
Did you migrate your complete previous settings folder (User Files) or did you start off bare without it?
Huracan
« Reply #28 on: August 20, 2015, 11:57:11 pm »
Started off without it :o
I did copy n paste someone elses User Files later
No worky :(
« Reply #29 on: August 21, 2015, 12:25:35 am »
Delete your GTA San Andreas User Files folder, or change it's name.
Make a shortcut to your gta_sa.exe
Right click the shortcut and choose properties
You'll see a field named Target, containing the path of the .exe e.g.
"C:\Users\Zeus\Downloads\GTASA\gta_sa.exe"Change it to:
"C:\Users\Zeus\Downloads\GTASA\gta_sa.exe" -width 1024 - height 768Click OK
Double Click the shortcut to start SP
Set your favourite (supported) resolution inside the game menu. I strongly recommend you to use something > 800x600 as your current display driver does not seem to support it anymore.
Close SP
Start SA-MP
done.
