Author Topic: SA:MP help!!! 5m ingame reward!  (Read 22990 times)
Huracan
Re: SA:MP help!!! 5m ingame reward!
« Reply #30 on: August 21, 2015, 12:32:46 am »
Delete your GTA San Andreas User Files folder, or change it's name.
Make a shortcut to your gta_sa.exe
Right click the shortcut and choose properties
You'll see a field named Target, containing the path of the .exe e.g.
"C:\Users\Zeus\Downloads\GTASA\gta_sa.exe"Change it to:
"C:\Users\Zeus\Downloads\GTASA\gta_sa.exe" -width 1024 - height 768Click OK
Double Click the shortcut to start SP
Set your favourite (supported) resolution inside the game menu. I strongly recommend you to use something > 800x600 as your current display driver does not seem to support it anymore.
Close SP
Start SA-MP
done.
Playa had this problem, you posted this, i tried this, but i didn't work, :( I'm do it again tomorrow but is no work
Offline bleeeh
  • SA-MP: [r]V.
« Reply #31 on: August 21, 2015, 01:00:09 am »
Right click the gta sa shortcut, click properties, go to the compatibility tab, tick the "run the program in blablabla", choose "Windows 98/Windows Me" and do the same for the samps shortcut.
« Last Edit: August 21, 2015, 01:04:20 am by Vail »
Huracan
« Reply #32 on: August 21, 2015, 01:03:05 am »
Check, check andddddddd CHECK :(
Should never have reinstalled Windows :/
Btw, on Windows 7 the screen resolution had different resolutions as to the ones on Win 8 rn so gonna install Win 10 tomorrow see if i can get 800x600 back somehow
« Last Edit: August 21, 2015, 01:04:39 am by Zeus. »
EpicHunter
« Reply #33 on: August 21, 2015, 09:51:01 am »
Dude, just delete gta sa user files, redownload gta_sa.exe from internet (v1.0), clean the game (especially from cleos lol)
Uninstall car - weapon mods
Try to check your gpu settings
The magic!
Huracan
« Reply #34 on: August 21, 2015, 11:04:39 am »
The magic!
Must be a software or smth
GPU?
Huracan
« Reply #35 on: August 21, 2015, 11:55:02 am »
Holy fuck i installed intel drivers set res to 1366xnot 768 and sp launched lemme test samp omfg
« Reply #36 on: August 21, 2015, 11:59:57 am »
there you go
Huracan
« Reply #37 on: August 21, 2015, 12:08:45 pm »
How to uninstall all these mods which came preloaded?
http://puu.sh/jJbRX/b5887eeff5.jpg
Also i got some trainer thing, is it necessary to keep because i'm not sure but i think it's hacks :3
EDIT: Downloading a new clean version of GTA with no hacks, i guess it'll be ok because i got the resolution problem sorted
Stupid fucking current GTA on v1.1 or smth
Downgrader patch fucking around so getting another v1
« Last Edit: August 21, 2015, 12:28:59 pm by Zeus. »
Huracan
« Reply #38 on: August 21, 2015, 12:57:25 pm »
Ok I'm up and running on 1024x768 which I'll need to get used to but it doesn't lag much so ok
I wanna give prizes to Aryan and EnzoMortelli
So 2.5m each guys hope you don't mind
Whenever we're in game just remind me on PM and I'll drop your cash to you
Lock this thread please :)
« Reply #39 on: August 21, 2015, 02:43:30 pm »
Solved and locked.
