Author Topic: Report  (Read 10424 times)
Offline HunTinG
Report
« on: January 03, 2016, 07:20:23 pm »
Nickname:[ITA]Same_Strow
Date: 3.1.2016
Reason of reporting: Uses illegal widescreen modifications, adjusting hitboxes and spawncamping (in his own video)
Evidence:https://www.youtube.com/watch?v=jUvKb0-AUyg&feature=youtu.be - Widescreen ingame
Also notice his videos , he uses Widescreen modifications on this server
https://www.youtube.com/watch?v=xHB1i5npIRk&feature=youtu.be - spawncamping , widescreen from player's perspective.
EDIT:
https://www.youtube.com/watch?v=w0lXLgYsQ1g&feature=youtu.be - Here's a solid proof ,which shows he clearly uses widescreen fix that adjusts hitboxes
« Last Edit: January 03, 2016, 07:26:53 pm by Sszx »
Offline essex
Re: Report
« Reply #1 on: January 03, 2016, 07:42:09 pm »
1st:
2nd:Need a video to show? OK! [url=https://www.youtube.com/watch?v=QpH9HKDBgyA&feature=youtu.be
« Last Edit: January 03, 2016, 07:47:27 pm by [ITA]Same_Strow »
Offline krystianoo1
Re: Report
« Reply #2 on: January 03, 2016, 07:49:12 pm »
Sorry for posting staff, but please note that the third video is a perfect example of 0.4's everlasting bug - the characters that are NOT in localplayer's view are not drawn so their shots are not synced, however they're heard - which might've made "Strow" turn around. While he is getting popped please note the crosshair movement which keeps going left; the shots landed in probably 5 spots - they might've hit him in the air or at the spot where he would land at Sszx's screen.
There is NO way of activating the widescreen option in the Display options - it is serverside and constantly checked by the server; editing the value with () will result in the screen getting constantly changed and shortly after a kick due to the client values not equaling the server values.
Enabling the asi is a whole different story; it IS possible (I am unsure of it's effects) but less than 2% of VCMP know how to do it and I doubt a person such as Strow with close to none (AFAIK) VCMP experience would be able to pull it off.
Again, sorry for posting!
EDIT: The most effective way to test it is naturally walk up to him on very close distance and use a shotgun/m4 while he's not moving, these situations do not prove anything.
Please note that on his videos he does NOT need to aim right/left to hit others.
« Last Edit: January 03, 2016, 08:11:11 pm by krystianoo1 »
Offline Howl
Re: Report
« Reply #3 on: January 03, 2016, 07:52:51 pm »
Your video doesn't prove shit, Same Strow. You should've posted your combat video instead of this. I'm witness, that this guy is using some sort of modification which adjusts his hitboxes (probably ws fix), i reported to milko in-game but he had some lag issues so he didn't test him.
Edit: I just searched his youtube channel and found,
This video:
http://youtu.be/F-rjzbvx87c
Posted by you, it's of 0.4 version, posted 2 days ago. It's clear that you can use ws fix, though you still use it.
Anything you want to say?
« Last Edit: January 03, 2016, 07:58:17 pm by BBA Reincarnated »
Offline essex
Re: Report
« Reply #4 on: January 03, 2016, 07:55:26 pm »
Need to reinstall the game? I reinstall the game now! HOW TO SHOW? I install the mod VCR, Background with girls, Mods gun TXD, Radar mode, this is all the mod i install!, i don't have any mod! Ok Krystianoo
« Last Edit: January 03, 2016, 08:05:43 pm by [ITA]Same_Strow »
Offline HunTinG
Re: Report
« Reply #5 on: January 03, 2016, 08:12:46 pm »
I agree with you,it seemt a little "weird" that video,but for now he is clearly using widescreen fix.He busted himself with his own videos.
Offline krystianoo1
Re: Report
« Reply #6 on: January 03, 2016, 08:15:00 pm »
How do you see his widescreen usage in his videos?
He aims at enemies where he sees them, shoots and still hits. His HUD does not appear offset in anyway.
Offline essex
Re: Report
« Reply #7 on: January 03, 2016, 08:16:41 pm »
There is the video:https://www.youtube.com/watch?v=Q0RjIZ2CRKs&feature=youtu.be
Anyone see the screen shot?
« Last Edit: January 03, 2016, 08:21:06 pm by [ITA]Same_Strow »
Offline Howl
Re: Report
« Reply #8 on: January 03, 2016, 08:26:25 pm »
Players shooting on the right of your head (from their view) lol, as i told krystianoo on irc, i had to shoot on the left of your head to pop it.
« Last Edit: January 03, 2016, 08:32:30 pm by BBA Reincarnated »
Offline essex
Re: Report
« Reply #9 on: January 03, 2016, 08:29:36 pm »
Man, why don't trust me? i don't have any mod for this widescreen, i'am a noob with this, this mods to be install, i view more, more video on youtube. I don't know what is this widescreen, and, how to use this widescreen if don't know what is!
« Last Edit: January 03, 2016, 08:33:51 pm by [ITA]Same_Strow »
Offline HunTinG
Re: Report
« Reply #10 on: January 03, 2016, 08:54:44 pm »
Well,krystianoo then explain the resolution in his videos,how do you explain that ? It's clearly widescreen fix by thirteenAG.I Know since I used it on original vice city sometime around 2014-2015
Offline essex
Re: Report
« Reply #11 on: January 03, 2016, 09:00:48 pm »
I find the problem, the problem is the resolution, sorry, i don't know this, i reinstall the game, and now is everithing ok, BIG SORRY, BUT I'AM NOOB, NOW I KNOW, AND I NOT TRY AGAIN! PLEASE SORRYYYYY :(((((((((((( 552X, vino in joc si incearca sa ma inpusti in cap
Offline krystianoo1
Re: Report
« Reply #12 on: January 03, 2016, 09:09:50 pm »
What's wrong with his resolution? The hud and radar positioning?????????????
1600x900 or anything else shouldn't cause any problems, many people that you yourself know use it and suffer no issues.
The widescreen fix is an ASIIIIIIIIIIIIIIIIIIIIIIIII file and they were blocked updates ago.
« Last Edit: January 03, 2016, 09:13:37 pm by krystianoo1 »
Offline HunTinG
Re: Report
« Reply #13 on: January 03, 2016, 10:37:47 pm »
Krystianoo,I have tested with my mates a widescreen fix and it works,in 0.4 , trust me,there's still a way to load asi.
EDIT:
https://youtu.be/Lxlx_8u8CFE?t=387
at the current moment compare where i shot to his perspective.You have video from him ^^
« Last Edit: January 03, 2016, 10:39:46 pm by Sszx »
Offline essex
Re: Report
« Reply #14 on: January 03, 2016, 10:58:29 pm »
Dar acum ce tot ai? Ai vazut ca am reeinstalat jocu-l, i-ar acum nu mai am nimic modat, mai schimba si tu discuţia, dar daca mi-ar da ban, pe tine cu ce te ajuta? Ești fericit amu ca ai si tu un report? Vezi ca te am si eu la mână cu ceva și în oricare moment il pot publica, mai veziţi de treaba ta și gata, eu nu primesc nimic daca ași avea hack-uri, joc jocul asta doar pentru distracţie. Te rog, lasa-ma în pace sa ma joc
