Author Topic: p4t admin abuse  (Read 4602 times)
Offline Fedor
p4t admin abuse
« on: March 19, 2016, 07:16:10 pm »
Nickname:p4t
Time and date (if known): today
Suspected method of cheat/exploit/rule break used: drowned without reasons..
Evidence: https://www.youtube.com/watch?v=lpbHjXlv56I&feature=youtu.be
Additional information: I killed him repeatedly and often becomes angry when they kill a lot, he called me '' lag'' and then I drown reasons for c-glitching.
« Last Edit: March 20, 2016, 12:30:58 am by Darfy »
Offline p4t
  • VC-MP Server Admin
  • awards VC-MP Most Friendly (2020)
Re: p4t admin abuse
« Reply #1 on: March 19, 2016, 07:37:05 pm »
It looked like it to me.  If I'm wrong, I'm wrong.  Let's correct it and move on with our lives.
-Add me on PSN-
Offline Fedor
Re: p4t admin abuse
« Reply #2 on: March 19, 2016, 07:52:50 pm »
Wrong? the same with a large number of players, then you want to continue to abusing without reasons? how are you tired of doing?
Or you want to leave this so? let's hope from others staff members.
« Last Edit: March 19, 2016, 08:04:13 pm by Fedor »
Offline NikY.Wolf / ValaK
  • SA-MP: [CO]NikY.Wolf
Re: p4t admin abuse
« Reply #3 on: March 19, 2016, 11:09:39 pm »
P4t was wrong, but he don't admin abuse every time, relax its  a simple drown, he admit the error.
2nd you use a ilegal mod, not seeing the leaves on the trees symbolizing an advantage if you use a sniper
Offline Darfy
Re: p4t admin abuse
« Reply #4 on: March 20, 2016, 12:20:51 am »
Quote from: Darfy
Removing your vegetation is allowed, as of now at least. This is solely because there's absolutely no way for us to make sure if you're having your tree leaves there or not. We can't see your end of the screen to check it, we can't access your game files to check it. We could ask you for a screenshot but how easy is it to temporarily replace the images inside the file. We have absolutely no control over the changes you guys make to your texture files.
If we were to set a rule against this, some players would continue using it anyway and there is not damn thing we could do about it. Both allowing and disallowing have their good and bad sides, I'm just going for the lesser bad.
Now as for the report, p4t admitted he made a mistake and that's that. The shotgun sync sometimes acts a little weird and when some of these random, odd glitches occur it's easy to mistakenly identify them as crouch glitching.
Again, apologies for the inconvenience. Case closed.
« Last Edit: March 20, 2016, 12:30:50 am by Darfy »
