Author Topic: Can't use vending machines  (Read 35167 times)
Offline RapisT
  • i'll fuckin rape ya all
  • SA-MP: HaRsH
« on: March 20, 2016, 07:07:53 am »
everyone can use vending machines but i cant
i tried each and every key of keyboard but fail
I re-installed Gta sa and samp client also
Neeeeeeed help as soon as possible
Offline Negative
  • sometimes...
Re: Can't use vending machines
« Reply #1 on: March 20, 2016, 09:55:59 am »
Enter, F or any key you use to enter car.
I can't post you.
Negative: 27 points
Offline RapisT
  • SA-MP: HaRsH
« Reply #2 on: March 20, 2016, 09:59:21 am »
Offline Negative
  • sometimes...
« Reply #3 on: March 20, 2016, 10:10:39 am »
Re-define control key for entering car then.
I can't post you.
Negative: 27 points
Offline =_Captain_=
  • Owner/Founder of VIP clan
    • VIP Clan Forums
« Reply #4 on: March 20, 2016, 10:15:48 am »
Drinking Soda is not good for you Rapist
Re Install your GTA try a different setup , i can give you a link if you wanna download the Gta SA full (Adult Version) (you should be 18+ to play that, are you ? xD )
Everything else works ??
« Last Edit: March 20, 2016, 10:21:31 am by =_Captain_= »
« Reply #5 on: March 20, 2016, 11:18:20 am »
change your keyboard
Offline Myle
  • SA-MP: Myle
« Reply #6 on: March 20, 2016, 11:26:36 am »
Maybe the vending machine doesn't like you? :/
Anyway
Can u enter car with 'f' or 'enter' without any problem???
I had this problem once.
There's always another way
Offline [BB]Diablo
  • Bleed or beat it!
  • SA-MP: [BB]Diablo
« Reply #7 on: March 20, 2016, 11:26:55 am »
It's not possible to disable vending machine unless it's blocked..check if your controls are default or changed...
Offline RapisT
  • SA-MP: HaRsH
« Reply #8 on: March 20, 2016, 11:48:05 am »
its soda not vine
yes
sure i will, gift me a new one
i am not a thing or item to be liked or disliked
yes i can
yes they are on defaults
EpicHunter
« Reply #9 on: March 20, 2016, 12:59:40 pm »
Stop using cleo mods and ASI plugins such as crashes.asi.
Offline [BB]Diablo
  • Bleed or beat it!
  • SA-MP: [BB]Diablo
« Reply #10 on: March 20, 2016, 01:38:38 pm »
Yep,so try changing it..try changing the default key to something else and check if it works or not...
Offline RapisT
  • SA-MP: HaRsH
« Reply #11 on: March 20, 2016, 02:43:32 pm »
i dont even have cleo folder neither i use any any kind of .asi files
Offline RapisT
  • SA-MP: HaRsH
« Reply #12 on: March 20, 2016, 02:43:54 pm »
tried
Offline RapisT
  • SA-MP: HaRsH
« Reply #13 on: March 20, 2016, 04:45:48 pm »
When reinstalling sa-mp & gta san andreas, it can be a waste of an effort if it's not uninstalled properly before. Remember to always delete the folder in my documents (especially gta_sa.set) and every single file that's left there after uninstalling in the program files folder as well.
If this does not work either, consider the problem to be somewhere outside the game.
PS: Moved to technical support.
today i re-installed windows too
« Reply #14 on: March 20, 2016, 04:50:51 pm »
Is this problem is only on multi or single ?
 Check it on single player its work there or not.
