Author Topic: [RS]MarqueZ  (Read 5337 times)
Offline Risse
[RS]MarqueZ
« on: May 10, 2016, 10:29:40 am »
hey want to ask something about the donor so far I have paid 4 or 5 times for donors to Sample every time we went but not the message I got maybe some mistake was a link gave me Reny [UB] to which I will send tohttps://www.paypal.com/uk/cgi-bin/webscr?cmd=_flow&SESSION=0eeKhGPgbQOJGMdibw_LjHDGelcWDJ4-U71tgD69nxngZN4GhtZqd6OzWUy&dispatch=5885d80a13c0db1f8e263663d3faee8dcce3e160f5b9538489e17951d2c62172
if you can get the donors and what to do :)
Re: [RS]MarqueZ
« Reply #1 on: May 10, 2016, 05:55:03 pm »
Let me help a bit. Going to ask you a few questions (directly translated to Serbian) and we will be glad if you answer them correctly.
 - Da li si stvarno poslao pare?
 - Ako jesi, kome (gde) si ih poslao i na koji način?
 - Ako su odgovori potvrdni na prethodna dva pitanja, onda moraÅ¡ obavestiti nekog od menadžera o tome i poslati sliku (ako već jesi) nekome od njih (Spitfire-u, Forgive-u, blewert-u ili NiGHTM4RE-u).
 - TakoÄ‘e imaj u vidu da je minimum 3 funte ako želiÅ¡ dobiti svoj donator rank tj. status. :)
Hopefully I'll get some honest answers there.
« Last Edit: May 10, 2016, 05:57:32 pm by run1 »
Re: [RS]MarqueZ
« Reply #2 on: May 10, 2016, 08:19:37 pm »
Runi, you got to translate this too
After you login to your Paypal account, go to https://www.paypal.com/myaccount/home
and then you should find something like this
click on the same name "Alasdair Popple" and then this should come to you
after that, go to your Microsoft bar, press on sniping tool and snip the picture like this, after that save it on desktop or wherever you want, go to imgur, press on upload pictures, press CTRL+V! after that you'll get a link, send it to Spitfire or any management and hvala! you got your donator level
