Author Topic: [RS]Risse_  (Read 4007 times)
Offline Risse
[RS]Risse_
« on: May 15, 2016, 03:33:09 pm »
If you can propose to abolish deatx eplosion server becomes stupid when there is no real fight once before which was not me the wrong way server is very I'm satisfied with the work done al overhangs the players rebelling like this
predlazem ако може да се укине deatx eplosion server postaje stupid nema prave borbe ko prije nekada sto je bilo mene nemojte pogresno da shvatite server je odlican ja sam zadovoljan vasim radom al previse se igraca buni radi ovoga
Re: [RS]Risse_
« Reply #1 on: May 15, 2016, 04:36:29 pm »
Risse, možeš izneti svoje mišljenje u General odsečku foruma na sličnu temu koju je Negative započeo.
Slobodno reci ako ti se sviđa ili ne, i napiši usput zašto.
Express your thoughts about certain feature in the topic started by our regular Negative.
« Last Edit: May 15, 2016, 04:38:12 pm by run1 »
