Author Topic: "Injected thread is hung" error started to take place recently, Any suggestion?  (Read 4420 times)
Offline OmaRosh
  • Nature hates change.
  • SA-MP: OmaRosh
Hi LWs,
This problem was happening occasionally for me when I try to join any vcmp server. It could be solved easily by retrying to join again.
But that is not the case here.
Recently, This error started to occur almost every time I want to connect to a server and it needed me to retry joining the server about (15-20) times until it works.
Then If I close the game and rejoin the server again it works perfectly (Until I restart my computer then again  >:( )
Is there any final solution to this problem?
any suggestions ?
Thanks in advance :)
« Last Edit: September 19, 2016, 05:46:39 pm by Darfy »
Injected thread hung, that means you are using outdated browser version, update your current VCMP 0.4 client to the latest one released.
Also, always have the same compatibility mode for VC:MP and GTA VC.
« Last Edit: September 16, 2016, 10:55:33 pm by Aryan »
I also faced this but i updated vcmp browser  from this try
http://forum.vc-mp.org/?topic=2638.0
Offline Azulej
  • You can't beat our meat.
It's common, don't worry about it just update your browser, try to join the server using enter instead of click, it works for me so it may work for you.
I have blackberry used to watch porn in it awesome mobile :)
Offline OmaRosh
  • SA-MP: OmaRosh
Thank you guys .. I already tried all of the above but It was solved somehow after I removed the "Run as administrator" checkbox from both the game and the VCMP client
I'll restart the computer and check..
Edit:
It's Working now thanks :)
« Last Edit: September 18, 2016, 11:25:59 am by Omarosh »
Offline Darfy
Glad you found a solution, locked.
