Author Topic: Level System 1.0  (Read 83899 times)
Offline [3D]TheRambo
Re: Level System 1.0
« Reply #15 on: November 05, 2016, 09:35:42 pm »
But it makes server lag
« Reply #16 on: November 21, 2016, 06:06:47 am »
Update:
In addition of level system, we have revised current spawn weapon set, so from now on, you'll get spawn weapons according to your level! Spawn weapon sets will soon be available at ammunation for all lazy players out there!
It was brought in to our attention that player(s) level keep on getting reset, we have fixed it and unfortunately, we had to wipe all levels stats till now, so, you'll have a fresh start from now on! Apologies for the inconvenience caused.  :)
« Last Edit: November 21, 2016, 06:09:41 am by Aryan »
« Reply #17 on: November 21, 2016, 07:11:02 am »
dunno if its because of that update or smthg else but when you type /s it doesnt count anything besides kills - ive done exports, reaction tests, purchased props etc. - all are shown 0
« Reply #18 on: November 21, 2016, 07:14:34 am »
yeah, achievements starts counting after you cross level 15.
Because, if achievements start counting from level 1, a player will be able to level up really fast and it will remove the whole concept of level system.
« Last Edit: November 21, 2016, 07:18:54 am by Aryan »
« Reply #19 on: November 21, 2016, 07:15:42 am »
Same for me.
« Reply #20 on: November 21, 2016, 07:19:54 am »
yeah, achievement starts counting after you cross level 15.
How does this make sense? Especially newcomers on lower levels use things like export and properties to gain money. Regulars at higher levels won't need it anymore.
« Reply #21 on: November 21, 2016, 07:22:48 am »
Each export gives you exp individually as well, so levels less than 15 can still benefit from that.
Offline SultanSaleem
  • SA-MP: SultanSaleem
« Reply #22 on: November 21, 2016, 12:07:43 pm »
Sometimes when you're on a higher level (eg: 20-25) u spawn with sniper, sawns, uzi, deagle and M4 but when u die, only left is deagle!!! Idk if it only happens to me or others too?! :/
Offline Progaming
  • Contra-props ftw
  • SA-MP: Seafury
« Reply #23 on: November 21, 2016, 11:33:00 pm »
Did Levels got resseted again?
I was level 11 and was afk for like some time and when i reconnected (today) i was level 1
Im not talking about the first reset tho
Update= Level was not loaded properly please spawn for the first time or relog message appeared
I did what was told but didnt receive my levels back
Yes i did several times
« Last Edit: November 21, 2016, 11:43:17 pm by Progaming »
« Reply #24 on: November 21, 2016, 11:49:34 pm »
That message appears on everyone's screen, no matter what level you are or have been a while ago. Level system indeed needs some fixing, and be sure that the problem will be solved as soon as possible.
« Reply #25 on: November 22, 2016, 01:52:43 am »
It is fixed. An older version was uploaded which caused you not to load your level. Your levels after the first reset will be loaded now.
« Reply #26 on: November 24, 2016, 07:19:21 am »
is it supposed to be like that every time you join, your data below "properties lost" is reset to 0 ?
« Reply #27 on: November 27, 2016, 08:20:51 am »
Can this level system be linked with the blewerts stats site?
Atm its pretty confusing there are 3 different levels - level:0 when u login; level in that stats page; level ingame
Offline Puranjay
« Reply #28 on: November 27, 2016, 09:52:14 am »
Agreed.
Having different level ingame and on forum is pretty confusing.
Offline blewert
  • The big cheese
  • SA-MP: trewelb
« Reply #29 on: December 04, 2016, 06:50:47 pm »
I will look into getting this fixed soon whenever I have time next!  :)
