Author Topic: Again i cant connect to the LW'S  (Read 8739 times)
Offline JuGNoO_Here
« on: January 22, 2017, 03:57:50 pm »
Guyz i got again that problem .. [ could not connect to ther server ]
Offline JuGNoO_Here
Re: Again i cant connect to the LW'S
« Reply #1 on: January 23, 2017, 08:06:30 am »
Last time for resolving the issue. I re-installed the window ...But i can't do this again and again...
Offline Casper.
  • Dark Fighters
    • DF Clan - Dark Fighters
  • VC-MP: [DF]Casper
  • PAC ID: 42662
« Reply #2 on: January 23, 2017, 10:15:21 am »
Try to run vcmp as Administrator or "Windows me 98"
Offline Zkq
« Reply #3 on: January 23, 2017, 02:24:59 pm »
The in the disc C you will find folders named with numbers like e5396369rouf5.    Remove them.  Abd if not re-install windows again
« Reply #4 on: January 23, 2017, 06:14:15 pm »
Press Ctrl + R and type cmd, and type nslookup
check it its timeout or not.(don't post any address ok)
All vcmp servers are not working for you or only LW server?
Press Ctrl + R and type cmd, and type ping 91.121.134.5
check out if this timeout then maybe an antivirus is blocking your ports or something maybe firewall, check your firewall is it blocking vcmp or not.
Edit: Check your router too if your are using maybe you have blocked something from there.
« Last Edit: January 23, 2017, 06:15:58 pm by SMD »
Offline JuGNoO_Here
« Reply #5 on: January 24, 2017, 02:30:15 pm »
Problems with all servers [ SMD ] i checked [ nslookup ]  shows time out......
Offline JuGNoO_Here
« Reply #6 on: January 24, 2017, 02:37:33 pm »
                  Where i can find that folder ? plzz post a exact address!!!!
Offline JuGNoO_Here
« Reply #7 on: January 24, 2017, 02:45:13 pm »
how to check in router for blocked connection?
Offline JuGNoO_Here
« Reply #8 on: January 27, 2017, 07:35:18 am »
SMD  i found your reply helpfull..Problem solved....
« Reply #9 on: January 27, 2017, 03:45:44 pm »
Sorry i can't reply you i was busy.
Btw good job.
