Author Topic: VC:MP/VC Pictures and Videos (Warning Big Pictures)  (Read 1272090 times)
0 Members and 7 Guests are viewing this topic.
Offline Eddy
« Reply #1335 on: July 06, 2016, 09:49:29 pm »
KTB (Kill The Boss event) by: Usmanulamin
Boss: myself
Offline The Milko
  • <message removed by RajPut>
    • Dark Negative Anti-Social
« Reply #1336 on: July 09, 2016, 07:52:30 pm »
Say hello to the first player ever to make it to the top of that tree!!!
Catapulted by the Milko!
Offline Jke
  • VC-MP Server Admin
« Reply #1337 on: July 12, 2016, 02:20:00 am »
Was a little derby :)
Offline Bhai
« Reply #1338 on: July 18, 2016, 02:13:58 pm »
http://imgur.com/a/3ivfO
my highest score by so far.
Offline KakaroT
« Reply #1339 on: July 21, 2016, 08:16:53 pm »
fly hacks ¯\_(͡ ͡° ͜ つ ͡͡°)_/¯
https://www.youtube.com/watch?v=t9hhx0kQqyA
edit:
Epic backup by Thanos
https://youtu.be/AikI4_Ihzkw
« Last Edit: July 22, 2016, 09:32:22 pm by KakaroT »
Kelvin Garcia Mendoza
« Reply #1340 on: July 23, 2016, 08:44:12 am »
Nice bhai.
Can you give me that texture mod? plz :v
Offline KakaroT
« Reply #1341 on: July 23, 2016, 11:48:24 am »
Nice bhai.
is retextured vice city by neo. The original pack isn't suitable for VC:MP you will need to remove and replace some stuff. It will be better if you download texture mods released by neo separately.
Offline Bhai
« Reply #1342 on: July 23, 2016, 12:14:45 pm »
Nice bhai.
what KakaroT said.
Offline Darfy
« Reply #1343 on: July 26, 2016, 08:48:31 am »
Neo's Retextured Vice City is basically a pack containing enhanced textures but like said it isn't really compatible with VC:MP or at least I couldn't run it when tested, probably need a downgraded exe or so. Or you could locate and export all the modifications he made into gta3.img because that's where the real changes are, the rest of the txd's outside gta3.img are just borrowed from different authors and tbh aren't even that high quality. But that is quite a lot of work. Until someone is willing to do that I suggest you install Hanney's VCVE pack.
Offline Azure
  • VUholic
« Reply #1344 on: July 26, 2016, 09:35:35 am »
-Link removed -
Just go here install neos mod and extract all files to gta vc directory
Worked for me
« Last Edit: August 05, 2016, 03:49:16 pm by Darfy »
Offline Darfy
« Reply #1345 on: July 26, 2016, 10:43:27 am »
-Link removed -
Worked for me
What's the exact filesize of the gta-vc.exe you're using with the pack?
Also be warned, the pack comes with a widescreen fix which in theory shouldn't work but in case it does you may be breaking the server rules without even being aware of it so just in case remove widescreen_fix_remake.asi before connecting to littlewhitey's.
« Last Edit: August 05, 2016, 03:49:27 pm by Darfy »
Offline Azure
  • VUholic
« Reply #1346 on: July 26, 2016, 11:25:28 am »
-Link removed -
Worked for me
yeah the widescreen isnt working but deleted it anyway and the gta vc.exe im using size is 2.94 MB just download the file from the link and paste evrything to the gta vc directory. worked smooth and everything looks great :)
« Last Edit: August 05, 2016, 03:49:38 pm by Darfy »
Offline Azure
  • VUholic
« Reply #1347 on: July 26, 2016, 11:31:03 am »
Offline Darfy
« Reply #1348 on: July 26, 2016, 01:08:27 pm »
My game crashes instantly at launch if I overwrite the default img with Neo's. Like I said it probably requires a cracked exe. Good if it works for you.
Offline Bhai
« Reply #1349 on: July 26, 2016, 01:12:37 pm »
also in Neo's VC, The handling.cfg file is kinda messed up. It increase the speed of vehicles especially of Skimmer, So I'll suggest make a backup of  handling.cfg of original VC and then replace it with Neo's.
