Author Topic: [LWW2017] The Littlewhitey's Weeks 2017 | 31.07.2017 - 14.08.2017  (Read 183777 times)
Offline Negative
  • sometimes...
Re: [LWW2017] The Littlewhitey's Weeks 2017 | 31.07.2017 - 13.08.2017
« Reply #30 on: August 03, 2017, 02:07:11 pm »
Yo playa.
First of all thank you for hosting the LWWs events. Now let's begin with the problem.  I told you even ingame, but hoping to get a better reply, I'm posting here.
First of all here are the rules written by you in your own post (this one).
-This is the LWW rules that have been applied since the very beggining of the LWWs. It is clearly stated in the rules that in order to win the Desert Turf Madness event "a gang of at least 3 members has to fight for the three turfs near desert ammunation." Your gang was declared the winner even though it managed to get only one turf, the one with the gun sign on map, with you claiming that the gang which manages to get that turf is the winner, which is clearly NOT stated in the rules. Something is wrong here.
-We were NOT allowed to /setspawn. You claim we were allowed but we all did spawn in one place as a spawn point was set for our group a few meters away from the turf (which is completely normal). The abnormality begins when Gamer spawns at his house inside the turf and you allow him to do so for more than 15 minutes. So, we have to run to get to the turf while he is spawning inside it and you call it normal. But in my opinion something is wrong here as well.
Hope you can clarify it :)
[15:07:15] * Admin (playa): you must capture the desert ammunation turf within 30 mins
It was his instruction and you should've followed it. ::)
« Last Edit: August 03, 2017, 02:09:09 pm by Negative »
I can't post you.
Negative: 27 points
Offline Renii
« Reply #31 on: August 03, 2017, 02:08:58 pm »
lol it doesnt say that u can change the rules whenever you want to
Jayce
« Reply #32 on: August 03, 2017, 02:09:50 pm »
I believe you missed an announcement via /say which lead to this confusion, it can be seen clearly in logs that he did say it's only 1 turf, the reason (from my point of view) the participating players count was low.
[14:06:50] * Admin (playa): all ready?
[14:06:52] (Gang) Jayce:
[14:06:53] * Admin (playa): gang day starting in 3
[14:06:54] <Badbear> yes
[14:06:55] <Dodo_> Yep
[14:06:55] * Admin (playa): gang day starting in 32
[14:06:55] (Gang) Jayce:
[14:06:57] * Admin (playa): gang day starting in 2
[14:06:57] (Group) Dodo_: Why?
[14:06:58] * Admin (playa): gang day starting in 1
[14:06:59] * Admin (playa): GO
[14:07:01] (Gang) playa:
[14:07:05] (Gang) Jayce:
[14:07:10] <[BB]S0n1c> first tell us what do we have to do in this event
[14:07:15] (Gang) playa: you must capture the desert ammunation turf within 30 mins
[14:07:20] <dankfrito> capture desert ammu turfs
[14:07:20] * Admin (playa): you must capture the desert ammunation turf within 30 mins
« Reply #33 on: August 03, 2017, 02:12:46 pm »
Thank you,
I told you that I forgot to update the topic ingame, which would change few other event details, the topic will be updated now.
I also told you all ingame to take the desert ammu turf @ 12:07 GMT, after i gave you all weapons and set your spawn, that means before i start the event.
The spawns were fairly located, your location had cars while ours didn't, plus don't forget that you had a privilege of camouflage and the other team didn't whine about it, gamer's house spawn was a privilege of his, i've told him to remove it.
Offline H3RO
« Reply #34 on: August 03, 2017, 02:22:58 pm »
-The desert ammu turf has three turfs and not one.
-Gamer could have easily got a car from his house.
-Both gangs could have used camouflage as you never said it was not allowed, so it can't be called unfair by anyone.
-Gamer used that spawn for more than half of the time while the event was being played.. You should have kicked him out of the gang if he continued to use his house as an unfair advantage, which would be pretty easy thing to do... Letting him abuse it for that long led to the other gang losing the turf..
To sum it up, bad organisation of the event, that's it all. All I can do now is hope that it won't occur in the coming events.
« Reply #35 on: August 03, 2017, 07:45:34 pm »
Gang Day is over.
Results:
Negative: 4 points
Reni12, [187]Gamer, : 3 points
Myle, Pops, [187]LukaZ, Jayce, Badbear, risi: 2 points
Dodo_, [187]Habdel, cOOda[SWEG], [BB]S0n1c, burntillusion: 1 point
Congratulations to [LWC.GangDay]Negative, the Champion of Gangs in littlewhitey's server.
Totals:
Negative: 23 points
Reni: 19 points
Jayce: 13 points
[187]Gamer: 12 points
Dodo_, BadBear: 11 points
Golk3r: 7 points
[3D]Spencer, cOOda[SWEG], Pops: 4 points
Myle: 3 points
[UFr]SuriAttackr, Halchter, Arnob, ItsWarHawk, eSportsRNotSports, Risi, [187]LukaZ: 2 points
[R2D]SnickerS, [HC]jav, [BB]S0n1c, burntillusion, [187]Habdel: 1 point
Melee Day will start tomorrow!
« Reply #36 on: August 04, 2017, 12:39:20 pm »
Melee Day will start after 6 hours, check the countdown
i had an emergency in real life
« Last Edit: August 04, 2017, 12:43:54 pm by playaâ„¢ »
Offline Dodo0
« Reply #37 on: August 04, 2017, 01:08:13 pm »
So, why you and your teammates used camouflages as it is against the rules too?
Look
He said desert ammunation turf not turfs.
It is your problem if you have some reading issues.
There were more than a vehicle near your spawn, which we didn't have.
The rules says, that it is forbidden for donators to set spawn, and forbidden to use camouflages. 3 of your team (Risi, Reni and S0nic) used camouflages (idk if there are more), and only Gamer who set his spawn at his house.
Also, S0nic was hidden from the map and shooting with sniper while using camouflage, so we didn't know where is him, we were getting killed without knowing his location so i think this wasn't fair tho.
And your teammates should have been kicked from the gang too for using camouflages.
You didn't get it that Playa let you use camouflages and let donators from our gang set their spawn locations (actually only Gamer who used it), and Gamer's house was having the same distance to the Ammu Nation and the distance between our spawn location and the Ammu Nation.
If you think it is unfairly for Gamer to set his spawn, it was unfairly too for your teammates to use camouflages.
« Last Edit: August 04, 2017, 01:11:33 pm by Dodo0 »
« Reply #38 on: August 04, 2017, 09:41:39 pm »
Melee Day is over.
Results:
Reni12: 9 points
SENNAAA: 1 point
Congratulations to [LWC.Melee]Reni12, the champion of Melee weapons on LW's.
Totals:
Reni: 28 points
Negative: 23 points
Jayce: 13 points
Golk3r: 7 points
Myle: 3 points
[R2D]SnickerS, [HC]jav, [BB]S0n1c, burntillusion, [187]Habdel SENNAAA: 1 point
Racing Day will start tomorrow!
Offline Renii
« Reply #39 on: August 04, 2017, 09:44:08 pm »
Pro melee :p
Ty playa
Offline GameRâ„¢
  • a kid but a treasure
  • SA-MP: [187]Gamer
« Reply #40 on: August 05, 2017, 06:17:51 pm »
playa... u said in special event day "train event: just like the offline mission Aztecs on train and GSF follow while shooting"
while actually they werent Aztecs they were Vagos Aztecs only exsist in GTA V
187 Is Love 187 Is Life
Offline Negative
  • sometimes...
« Reply #41 on: August 05, 2017, 07:49:09 pm »
Varios Los Aztecas aka Aztecs, gang lead by Cesar Vialpando, wears light blue clothes.
I can't post you.
Negative: 27 points
Offline GameRâ„¢
  • SA-MP: [187]Gamer
« Reply #42 on: August 05, 2017, 07:58:53 pm »
but still they are Vagos :X
« Reply #43 on: August 05, 2017, 08:53:44 pm »
Racing Day is over.
Results:
Badbear: 15 points
Reni12: 9 points
dankfrito: 4 points
[187]Gamer: 3 points
[JOKER]Hyper, Jayce, [R]EnzoMortelli, [MM]Trung: 1 point
Congratulations to [LWC.Race]Badbear, the champion of races in littlewhitey's.
Totals:
Reni: 37 points
Negative: 27 points
Badbear: 26 points
[187]Gamer: 15 points
Jayce: 14 points
Dodo_: 11 points
Golk3r: 7 points
Myle: 3 points
[R2D]SnickerS, [HC]jav, [BB]S0n1c, burntillusion, [187]Habdel SENNAAA, [JOKER]Hyper, [R]EnzoMortelli, [MM]Trung: 1 point
Special Events Day will start tomorrow!
Offline Kibo
  • Don't be a dick!
  • SA-MP: [cB]Kibo
« Reply #44 on: August 05, 2017, 09:28:21 pm »
Thanks playa! ;D
