Author Topic: RajPut . cheat aimbot  (Read 2673 times)
Offline Onanist
  • SA-MP: onanist
« on: August 24, 2017, 03:25:53 am »
Nickname: RajPut
Time and date (if known): all days
Suspected method of cheat/exploit/rule break used:  cheat aimbot
Evidence: https://youtu.be/DNLVzKMN7UA
https://www.youtube.com/watch?v=-TEttIKyoNQ
https://www.youtube.com/watch?v=KMfInrFrw_I
Additional information:
This guy like others use the aimbot and they do not play cleanly. In your videos is the test
Offline SuriAttacker
Re: RajPut . cheat aimbot
« Reply #1 on: August 24, 2017, 03:55:17 am »
That's not aimbot. He's just playing with a low sensitivity. You can also change your mouse sensitivity either by going through your game menu > options > controllers setup > mouse settings and you should find an option to change your sensitivity or you could change your sensitivity by writing a client command : /setconfig game_sensitivity <value>
I believe Rajput has also changed his game sensitivity ratio what seems to be the y-sensitivity. This can be changed by writing the client command : /setconfig game_sensitivity_ratio <value>
And then you've some mouse(probably gaming mice) that comes with some softwares that provides features to adjust the mouse sensitivity.
I hope this clarifies. Report Denied.
