Author Topic: littlewhitey's Christmas Tree Competition 2018!  (Read 29194 times)
« on: December 05, 2018, 08:28:40 pm »
littlewhitey's celebrates Christmas by adding a nice tree to the SA-MP server. This can't be done without your input!
First of all, make sure your version of GTA: San Andreas is downgraded to V1.0. You can do this using this patch. You will need a Map Editor to create your tree. Actually, there are a few tools you can use. I will try to explain how mapping works with 'MTA Map Editor'.
First you will have to download and install MTA.
After you're done: run it as administrator and click Map Editor.
There you go. Now you can collect objects, put them together and figure everything out.
Other:
SA-MP Map Editor: Download
Alternative Map Editor 1: Download
Alternative Map Editor 2: Download
MTA with SA-MP 0.3.7 Objects: Download(Recommended!)
Well I suggest you google your problem first, there is alot of information out there regarding GTA Map Editors. If you really have a specific question, and can't find any information, feel free to post your problem.
Some useful sites:
http://forum.ragezone.com/f500/tutorial-use-map-editor-532685
http://weedarr.wikidot.com/mapping
Q: Why can't I save or load my map anymore?
A: Make sure you run it as Administrator at all times. If this does not the issue, look for the file 'Editor_Dump' in MTA San Andreas\server\mods\deathmatch\resources
and delete it.
The tree must be placed somewhere on The Strip.
When you submit your tree, make sure to include at least 3 screenshots.
 The object limit is set to 400.
 Mazimum amount of lights in the tree is set to 65.
 When converting your tree to SA-MP format, use WWW.CONVERTFFS.COM
 Keep your source code private.
 The winner will be picked using a poll: Whoever gets the most votes wins.
 Deadline is set for DECEMBER 20th, 2018!
[b]Ingame nickname:[/b]
[b]Amount of objects used:[/b]
[b]Amount of lights used:[/b]
[b]Submission date:[/b]
[b]Screenshots:[/b]
1st prize: Donator Status + your winning Tree added to the server!
2nd prize: $5,000,000 in cash
3rd prize: $3,000,000
« Last Edit: December 05, 2018, 08:33:20 pm by PawnFox »
Offline Kibo
  • Don't be a dick!
  • SA-MP: [cB]Kibo
Re: littlewhitey's Christmas Tree Competition 2018!
« Reply #1 on: December 10, 2018, 06:48:39 pm »
Good luck all! ;D
« Reply #2 on: December 22, 2018, 10:01:45 pm »
Since no one signed up for this event, this year the tree will be provided by littlewhitey's development team.
- The tree is now on the server, it can be found near pirate ship.
