Author Topic: SA-MP: Exception error occured  (Read 19656 times)
Offline PANZER24
« on: December 24, 2018, 11:11:33 am »
Today I installed SA-MP on my san andreas copy and wanted to play some multiplayer, Once I open a server the game crashes and gives me an "exception error occured"
Singleplayer works fine, tried compatibility and DEP, didn't work. I don't know if this is the correct section to post such things, but I need help.
(I'm on windows xp sp3 btw)
Offline PANZER24
Re: SA-MP: Exception error occured
« Reply #1 on: December 25, 2018, 08:00:00 am »
I won't download all of that just for a crack...
Offline Myle
  • SA-MP: Myle
« Reply #2 on: December 25, 2018, 06:17:37 pm »
Can you show us the log of the error please?
There's always another way
Offline Renii
« Reply #3 on: December 25, 2018, 07:10:22 pm »
Try changing your gta-sa.exe and samp compatibility to windows xp sp3 or windows 98
They should both be the same
Offline PANZER24
« Reply #4 on: December 26, 2018, 10:39:09 am »
SA-MP 0.3.7-R3
Exception At Address: 0x004C67BB
Base: 0x02AA0000
Registers:
EAX: 0x00000000 EBX: 0x0000008B ECX: 0x00B4C2D4 EDX: 0x0023FAC4
ESI: 0x00B4C2D4 EDI: 0x00000008 EBP: 0xFFFFFFFF ESP: 0x0023FAE0
EFLAGS: 0x00210206
Stack:
+0000: 0x0264C2B8   0x005B74AC   0x00000116   0x00B71848
+0010: 0x00869834   0x0023FB3C   0x0023FB60   0x0023FBD4
+0020: 0x0023FBBC   0x0023FB8C   0x0023FBA4   0x0023FB4C
+0030: 0x0023FB48   0x0023FB50   0x0023FB44   0x0023FB40
+0040: 0x0023FB78   0x0023FBEC   0x0023FC28   0x00000008
+0050: 0x0264C2B8   0xFFFFFFFF   0x008E2C64   0x00000116
+0060: 0x00000009   0x00000009   0x00000000   0x00001FFF
+0070: 0x6C6C756E   0x00000000   0x00006367   0x00000000
+0080: 0x6466766C   0x00000031   0x00000026   0x0023FBAC
+0090: 0x00C9C300   0x00000090   0x5F444550   0x45505954
+00A0: 0x4E45475F   0x06366600   0x00001000   0x54415453
+00B0: 0x5249465F   0x4E414D45   0x4E4F4900   0x00000000
+00C0: 0x00000E1A   0x74617773   0x04280100   0x00833E01
+00D0: 0x042801EC   0x0082B6A4   0x00000004   0x45524946
+00E0: 0x004E414D   0x008E2CB0   0x00B71848   0x00000E1A
+00F0: 0x0023FBC0   0x6466766C   0x00000031   0x00825EA4
+0100: 0x0088BE50   0xFFFFFFFF   0x0082AD25   0x43494F56
+0110: 0x45475F45   0x4F4E5F4E   0x43494F56   0x00820045
+0120: 0x008E2CB0   0x00823812   0x00000008   0x00B71848
+0130: 0x008E2C64   0x00B718C4   0x0000000A   0x008E2CB0
+0140: 0x00B71848   0x0023FC08   0x43494F56   0x45475F45
+0150: 0x4F4E5F4E   0x43494F56   0xFFFF0045   0x00823812
+0160: 0x005389C4   0x00B71848   0x00000184   0x008E2CB0
+0170: 0x00536F96   0x008E2CB0   0x00B71848   0x00000200
+0180: 0x0264C2B8   0x005B8659   0x00B71848   0x008E2C90
+0190: 0x00B7184C   0x00263BE8   0x00000000   0x008E2CB0
+01A0: 0x00000121   0x0264C2B8   0x00000000   0x41544144
+01B0: 0x4445505C   0x44492E53   0x44490045   0x00230045
+01C0: 0x7E3A9083   0x0023FCF0   0x00000000   0x00000000
+01D0: 0x04198C24   0x04198C24   0x0023FCD4   0x7E3A9083
+01E0: 0x0023FD0C   0x00000000   0x00000000   0x04198C24
+01F0: 0x04198C24   0x04198C24   0x04195D0C   0x00030201
+0200: 0x0023FCE8   0x7E3A980C   0x04198C58   0x007F91EC
+0210: 0x0003025E   0x008E2C90   0x04195D0C   0x00263BE8
+0220: 0x00000000   0x04198C24   0x00000000   0x00000000
+0230: 0x00000000   0x00000320   0x00000258   0x76AE4E7B
+0240: 0x07DEEF5E   0x00000000   0x00002710   0x00000000
+0250: 0x715E5020   0xFFFFFFFF   0x76AE2AEE   0x76AEADFF
+0260: 0x76B00220   0x00000000   0x00073316   0x00000000
+0270: 0x00263BE8   0x007EF391   0x00000000   0x04198C24
SCM Op: 0x0, lDbg: 0 LastRendObj: 0
Game Version: US 1.0
I am already using windows xp service pack3, I tried it and didn't work
@myle after I close the log I receive an adress memory error.
Here's a photo of it
Offline Myle
  • SA-MP: Myle
« Reply #5 on: December 26, 2018, 12:49:27 pm »
> Have you tried running it as admin after setting the compatibility mode?
> Try reinstalling GTA SA and SAMP
Offline PANZER24
« Reply #6 on: December 26, 2018, 02:50:01 pm »
is there such setting on windows xp sp3? didn't try it
I rather not perform this action as it will take me time and I am limited to one hour per day when staying on computer, also I don't think it will affect anything because I installed GTASA and SAMP at the same day. without downloading any other mods.
The first time I launched SAMP, I could see the loading bar and then I see the water(I think it is part of the map that is not completely rendered)t and "connecting to xxx.xxx.xxx.xxx (server ip)" and after that the game crashes with the exception error. and I cannot play SA:SP after this only when I end the "gta_sa.exe" processus (Yep, it stays there even after I qui SAMP)
from that point whenever I connect to a server the splashscreen appears then crashes, without showing me the loading bar or water around.
these are some additional info concerning the issue.
Offline PANZER24
« Reply #7 on: December 28, 2018, 05:44:25 pm »
Not meaning to be rude but bump!
Offline Myle
  • SA-MP: Myle
« Reply #8 on: December 29, 2018, 09:22:05 am »
Can you only uninstall the SA:MP client and install this one from the link please? https://drive.google.com/open?id=1aGZznjvmR0qhhNfSvYIZ4T_FeySvABP1
Offline PANZER24
« Reply #9 on: December 31, 2018, 04:21:06 pm »
Did not work. I tried MTA:SA and did not work either, giving me a similar adress crash error.
is there something I need to download like c++ or .net framework?
and is there "run as administrator" option in windows xp sp3?
Offline Delucio
« Reply #10 on: March 15, 2019, 02:07:27 pm »
There should be a "run as admin" button, no? It's not there when you right click?
Offline PANZER24
« Reply #11 on: March 15, 2019, 10:56:20 pm »
As far as I remember it is not there, I am using winXP.
