Author Topic: Could not start process. (740) - Error while connecting to server  (Read 45014 times)
Offline Rootedox
  • @Missile
Can anyone help me :)
Auto-kicked:[ Biscuit. ] Reason:[ Checksum failed ]
« Last Edit: December 08, 2022, 03:40:49 am by Rootedox »
Acooooona mananaaaa ..
Offline cool3^
  • VC-MP Server Admin
  • SA-MP: [MK]cool3
  • VC-MP: [MK]cool3
Re: Auto-kicked:[ Biscuit. ] Reason:[ Checksum failed ]
« Reply #1 on: November 28, 2022, 12:59:42 pm »
Please allow me to question you.
1. Do you have any.dll files in your game directory? (The only acceptable.dll is mss32.dll, which should be located in your game folder.)
2. What error message do you receive when you attempt to connect to the server?
Offline Rootedox
  • @Missile
« Reply #2 on: November 28, 2022, 07:56:19 pm »
1. No, just the mss32.dll
2. i got this : https://imgur.com/jQxhPkj
Offline cool3^
  • SA-MP: [MK]cool3
  • VC-MP: [MK]cool3
« Reply #3 on: November 28, 2022, 08:14:55 pm »
Delete ddraw.dll from your game's directory. You are unable to join because the file "ddraw.dll" is located in your game folder; additionally, you will be unable to join the server until this dll is removed from your game folder.
Offline Rootedox
  • @Missile
« Reply #4 on: November 28, 2022, 08:21:10 pm »
But when i delete it, the game don't open! What should i do?
Offline cool3^
  • SA-MP: [MK]cool3
  • VC-MP: [MK]cool3
« Reply #5 on: November 28, 2022, 08:47:02 pm »
If you really need to use a ddraw component to get VC to work use this one as it should be allowed through the anti-cheat checks:
Quote from: Silent
GTA III/GTA VC DDraw Component: (last update: 20.05.2018)
This ddraw.dll component fixes some game issues which couldn't be addressed from within the ASI due to the fact ASI files load relatively late in those games.
  • If the settings file is absent, the game will now default to your desktop resolution instead of 640x480x16
  • DirectPlay dependency has been removed - this should improve compatibility with Windows 8 and newer
  • The game will not crash on startup if Data Execution Prevention is enabled for all applications anymore
  • "Cannot find enough available video memory" error showing on some computers has been removed
  • Path to the User Files directory is now obtained differently, hopefully increasing compatibility and future-proofing the games more
  • FILE_FLAG_NO_BUFFERING flag has been removed from IMG reading functions - speeding up streaming
  • All censorships from German and French versions of the game have been removed
  • Fixed an issue which would cause games to freeze if III/VC/SA were running at the same time
You can get it here: https://www.gamepressure.com/download.asp?ID=80139 and it will solve your problem.
« Last Edit: November 28, 2022, 08:53:50 pm by cool3^ »
Offline cool3^
  • SA-MP: [MK]cool3
  • VC-MP: [MK]cool3
« Reply #6 on: November 28, 2022, 08:58:44 pm »
If the previous link does not work, try this one: https://silent.rockstarvision.com/uploads/SilentPatchDDraw.zip
Offline Rootedox
  • @Missile
« Reply #7 on: November 29, 2022, 08:07:45 pm »
Thanks Cool,  but when i try to connect now i get this Error : https://imgbox.com/0a9ar8Uq
« Last Edit: November 29, 2022, 08:20:15 pm by Rootedox »
Offline cool3^
  • SA-MP: [MK]cool3
  • VC-MP: [MK]cool3
« Reply #8 on: November 30, 2022, 02:35:57 pm »
VC:MP is unable to locate your EXE. Return to the settings menu and look for the Vice City folder again.
Offline Rootedox
  • @Missile
« Reply #9 on: December 06, 2022, 09:42:04 pm »
it still dosen't work :/
Offline Waluta
  • VC-MP: Waluta
  • PAC ID: 39059
« Reply #10 on: December 07, 2022, 12:07:21 am »
Make sure you have patch 1.0 :p
Offline Rootedox
  • @Missile
« Reply #11 on: December 07, 2022, 01:23:45 pm »
Please could you be more specific, where can i find this patch?
Offline Waluta
  • VC-MP: Waluta
  • PAC ID: 39059
« Reply #12 on: December 07, 2022, 11:23:51 pm »
It will download it and then paste it into the game folder.
https://www.moddb.com/addons/gta-vice-city-patch-for-no-cd-v10/
Offline Rootedox
  • @Missile
Could not start process. (740) - Error while connecting to servers
« Reply #13 on: December 08, 2022, 03:33:28 am »
Still same error :/     https://imgbox.com/0a9ar8Uq
« Last Edit: December 08, 2022, 03:39:18 am by Rootedox »
Offline Waluta
  • VC-MP: Waluta
  • PAC ID: 39059
Re: Could not start process. (740) - Error while connecting to server
« Reply #14 on: December 08, 2022, 09:34:39 am »
Write about your problem here https://forum.vc-mp.org/ albo https://discord.gg/PbmCcpTk They will solve your problem faster than us here.
