Author Topic: Stats Userbars [Old thread - Check the new sticky ! ]  (Read 47953 times)
Re: Stats Userbars
« Reply #90 on: November 14, 2014, 05:19:10 pm »
*\o/
« Last Edit: November 15, 2014, 07:12:09 am by EnzoMortelli »
Redirect Left
Re: Stats Userbars
« Reply #91 on: November 14, 2014, 05:43:04 pm »
Updated my post.
The link will be similar, although a bit different, probably sig.php?username={YOURNAME}&img={IMAGE_CHOICE}, as I do not have access to the mod_rewrite files to achieve what it used to be, we'd need to find admin to do that. Because mine will have settings, it'll need to be done seperately, so people can customize it, selecting their own background image, size and black or white text
« Last Edit: November 14, 2014, 05:49:52 pm by Redirect Left »
Re: Stats Userbars
« Reply #92 on: November 14, 2014, 06:10:52 pm »
Redirect Left
Re: Stats Userbars
« Reply #93 on: November 14, 2014, 07:16:48 pm »
Offline !!AngeL!!
Re: Stats Userbars
« Reply #94 on: November 14, 2014, 07:25:29 pm »
also guys don't forget to make for vc-mp too pl0z :D
Redirect Left
Re: Stats Userbars
« Reply #95 on: November 14, 2014, 07:34:42 pm »
I only have access to the SA:MP database.
In other news, the test url is the following, and no it doesn't work yet, its an example http://stats.littlewhiteys.com/stats/sig.php?name=NAMEHERE&size=SIZE
the real deal won't be hosted at pass.littlewhiteys, its only there whilst i'm testing it because its the only folder i can modify.
Naturally, you would replace 'NAMEHERE' with your server name, in lowercase, and 'SIZE' with one of three things, 'l', 's' or 'vs', meaning large, small, or very small, see the sizes in my previous post.
As you can see, its easy to choose what size you'd like, within the next few days, i'll try finding the time to make it actually print stats out.
if you get an error saying the image cannot be displayed, or it just doesn't show, then you have selected an invalid username or size
« Last Edit: November 14, 2014, 07:39:48 pm by Redirect Left »
Re: Stats Userbars
« Reply #96 on: November 14, 2014, 08:11:04 pm »
Redirect Left
Re: Stats Userbars
« Reply #97 on: November 14, 2014, 08:53:57 pm »
it was like that, before.
Nothing I can do with that, like I said before I can't do graphics.
Offline SKY
  • Quad Buddy
Re: Stats Userbars
« Reply #98 on: November 14, 2014, 09:59:33 pm »
Maybe you an collab with blewert if he is available
Since 2008
Re: Stats Userbars
« Reply #99 on: November 15, 2014, 07:50:50 am »
As close as i could get to the original one:
.rar archive with the raw .bmp files in different color variations + .ttf for the userbar font at http://www.mediafire.com/download/79x7ig8ocigkdln/LWuserbars.rar
Font should be white with black border and make sure not to use any font anti-aliasing. Original two-line layout suggests 7pt fontsize.
« Last Edit: November 15, 2014, 11:22:41 am by EnzoMortelli »
Re: Stats Userbars
« Reply #100 on: November 15, 2014, 01:48:16 pm »
Awesome work Redirect Left,keep it up! The signature thingy you've started working on looks cool.I'm so proud of you boi! :D
Redirect Left
Re: Stats Userbars
« Reply #101 on: November 15, 2014, 03:12:40 pm »
With the help of Enzos files, i've now got the right font with the right font colors drawing onto the right background, by tonight I am hoping to have some stats drawn onto it too.
Re: Stats Userbars
« Reply #102 on: November 15, 2014, 03:28:59 pm »
oh boy :D
Redirect Left
Re: Stats Userbars
« Reply #103 on: November 15, 2014, 04:24:41 pm »
They've been updated, they now show your stats (userbar / very small only). I'll do the rest another time, the bigger ones will show more stats, such as bank and what not.
the code is
http://stats.littlewhiteys.com/stats/sig.php?name=server_name_in_lowercase&size=vs
You can select what color background you want if you don't like the default, the options are below, for each, add the following to the end of the url
&img=rose
&img=sand
&img=purple
&img=green
&img=black
&img=aqua
no &img or &img=standard
Whenever I get access, I will move these to a stats directory, they're only in /pass/ as they're currently the only thing i have access to, but feel free to use them now!
I am hoping that using these, we will get more players, as we attract them out of curiosity, so please feel free to use them on signatures on other forums, this is why I have put 'littlewhiteys lvdm' instead of ratio, i might change it later.
« Last Edit: November 15, 2014, 04:35:02 pm by Redirect Left »
Re: Stats Userbars
« Reply #104 on: November 15, 2014, 04:30:43 pm »
Hahaha,these are looking insane,like they used to  :D
