Author Topic: [I] /IRCPM  (Read 6378 times)
[I] /IRCPM
« on: June 17, 2009, 05:50:19 pm »
Can we have a returned message to the player who sends a /ircpm to someone?
because now it returns 1; but if you forget it could be spammed
something like (this needs adaptation, since I don't know the actual /ircpm code)
if(!strcmp(cmdtext, "/ircpm", true))
        if(cmdtext[] == 0) {
        SendClientMessage(playerid, 0xFF0000FF, "USAGE: /ircpm [msg]");
        return 1;
        new string[128];
        GetPlayerName(playerid, string, sizeof(string));
        format(string, sizeof(string), "PM to IRC sent: %s", string);
        SendClientMessage(playerid,COLOR, string);
        return 1;
Also a command to see donator commands ingame:
if(strcmp(cmdtext, "/commandtoseedonatorcommands", true)==0)
SendClientMessage(playerid,COLOR_YELLOW, "Donator Commands: /nos, /setspawn, /resetspawn, /flowers, /donators, /ircpm");
« Last Edit: May 18, 2010, 12:23:55 pm by Hazard »
Re: Donators suggestion.
« Reply #1 on: June 17, 2009, 05:52:35 pm »
Lol, Faraday got into pawn  :D
« Reply #2 on: June 17, 2009, 06:03:06 pm »
faraday fails at pawn.
« Reply #3 on: June 17, 2009, 06:09:59 pm »
Thanks for the suggestions, they will be implemented on the next restart and a command for donator commands will be /dcmd
« Reply #4 on: June 17, 2009, 06:12:22 pm »
dcmd! D:
« Reply #5 on: June 17, 2009, 06:50:57 pm »
dcmd! D:
or whatever command you like.
@eDiT: it was just an example. and I also stated so.
Offline Carolicious
« Reply #6 on: June 17, 2009, 07:24:36 pm »
« Reply #7 on: June 17, 2009, 07:27:49 pm »
« Reply #8 on: June 18, 2009, 03:49:39 am »
dcmd_dcmd(playerid, cmdtext[])
   #pragma unused playerid
   #pragma unused cmdtext
   SendCientMessage(playerid, COLOR_RED, "OMG its dcmd used in a dcmd command xD ");
   return 1;
yea i was bored and that only took 1 sec :C
