Author Topic: PING PROBLEM NEVER HAPPENED TO ME!!>:(  (Read 9302 times)
Offline DES_Killer
« on: September 22, 2009, 04:04:04 am »
Admin -LWBOT-
Time: 2:59:14
Date: 22/09/2009
Reason: Average ping exceeds the limit of 450 [Average: 558]
I JUST LIVE IN HONDURAS THIS IS INJUSTICE!  >:(
MAYBE HE CAN MOVE TO HONDURAS OR TO CENTRAL AMERICA LOL =s
« Last Edit: September 22, 2009, 04:21:52 am by DES_Killer »
Re: PING PROBLEM NEVER HAPPENED TO ME!!>:(
« Reply #1 on: September 22, 2009, 04:05:57 am »
The server is located in Europe, that's probably why.
« Reply #2 on: September 22, 2009, 06:39:23 am »
Well, time to start packing up I guess. LW's, we're going to HONDURAS!
Offline Chainer
« Reply #3 on: September 22, 2009, 07:12:14 am »
I've actually had ping problems recently too... Usually my ping used to be around the 150-200 range, but recently it sometimes randomly jumps between 200 and 500 or so, and I often get a short delay while typing things into chat.
Don't know if it's on my end or not, just putting it out there.
Offline Champion
« Reply #4 on: September 22, 2009, 07:31:56 am »
Must be all you Americans and Europeans  :P
Canada is just fine  :-*
Offline Caturday
  • Im back baby!
« Reply #5 on: September 22, 2009, 08:26:52 am »
still fine for me when I play 70-100
« Reply #6 on: September 22, 2009, 09:39:01 am »
I had the same problem! It normally is 50 but I saw it jump to 51 once!!!! :o
« Reply #7 on: September 22, 2009, 02:00:25 pm »
stop downloading your gayporn and its all fine
« Reply #8 on: September 22, 2009, 10:58:27 pm »
mine has dropped quiet alot its from about 175 to 150 when i first started mine was over 200
« Reply #9 on: September 22, 2009, 11:45:51 pm »
i mhave had problems also it used to be 130 now its 155-166 rlly weird and i dotn download anything :(
Offline Kaiser
« Reply #10 on: September 23, 2009, 02:09:23 am »
DES Killer.
Supongo que hablas español, mira aqui ay mucha gente que no ayuda (Como deben de hacerlo),solo saben hablar, se supone que ellos te podrian ayudar, pero se nota que no es asi.
[Spanish]:
Bueno para poder jugar al sa-mp tenes que tener minimo 1mpb de velocidad de tu internet, otro es que cuando vayas a jugar al sa-mp cierres todos los programas y solo dejes el sa-mp andando.
Tambien puede ser que tengas programas que te afectan tu ping (Como intercambiadores de archivos p2p), Etc; para arreglar ese problema los tenes que desactivar, cerrar, desinstalar, etc.
Nota: Jamas van a mover el server a Honduras o Centroamerica, ademas de que muchas veces el ping depende de la velocidad de internet.
[English]
Well to play sa-mp you have to have minimum 1mpb your internet speed, another is that when you go to play sa-mp closing all programs and only leave the sa-mp walk.
Also you might have programs that will affect your ping (as P2P), etc; to fix that problem's you have to disable, close, uninstall, etc.
Sorry for my english.
¿Y asi quieren llenar el server?...
« Last Edit: September 23, 2009, 02:22:23 am by Brembo »
« Reply #11 on: September 23, 2009, 05:33:57 am »
Mine is 95-105 pretty much all the time, only when neighbour downloads then my ping is 300+.
« Reply #12 on: September 23, 2009, 05:42:40 am »
save it for the blog
Offline Caturday
  • Im back baby!
« Reply #13 on: September 23, 2009, 08:20:05 am »
Aparantly porngay takes up less bandwidth
« Reply #14 on: September 23, 2009, 09:40:53 am »
Uploading kicks ya ping waaaaa up - so stop uploading "Stuff" to the interweb!!!!
