Author Topic: Performance upgrades[REJECTED]  (Read 6211 times)
Offline enkei
  • SA-MP: enkei
« on: November 05, 2009, 07:52:38 pm »
Yea, dont tell me its impossible because i know it's not.
Have performance modifications availible at transfenders. (eg. Weight reduction kit, Engine performance kit, tires)
All you'd have to do is edit the vehicle's row in the handling.cfg file. Its easy. There, you can edit the mass, and aerodynamics of a vehicle.
if someone selects weight reduction, their vehicle's mass gets lowered. Easy.
The hard part is making it vehicle specific. Modifying the mass on that particular car, instead of every car of the same model currently on the server.
Offline Swanson
Re: Performance upgrades
« Reply #1 on: November 05, 2009, 07:57:09 pm »
Sounds easy maybe, but I don't know if this is possible. Did you see this in other servers yet?
« Reply #2 on: November 05, 2009, 07:58:12 pm »
Lol, the server cant edit your handling.cfg file
Offline Swanson
« Reply #3 on: November 05, 2009, 08:05:07 pm »
My idea. If you would change the config file that would mean every car (of the type you changed) in the entire game gets affected. And now I think better about it, like Dominator says, the server can't edit your config file cause when you play online, the sa-mp engine uses your local config file and not the file on the server.
So it's impossible.
« Last Edit: November 05, 2009, 08:07:51 pm by [ExR]masterbeef »
Offline enkei
  • SA-MP: enkei
« Reply #4 on: November 05, 2009, 08:07:40 pm »
Dominator- The server has its own handling.cfg file. YOU use their file. Not your own. You use your own when you play offline, in regular gta:sa.
« Reply #5 on: November 05, 2009, 08:08:36 pm »
Hmm , i don't know .. But i think this suggestion isn't possible to make.
Offline Swanson
« Reply #6 on: November 05, 2009, 08:09:21 pm »
So where did you see this stuff in action? I would like to know. Thinking of something that might work doesn't mean it really does. And like I said, even if you could change the config file on the server, it would mean every car gets affected. I don't think there's a solution for that.
« Reply #7 on: November 05, 2009, 08:09:56 pm »
YOU CANT DO THAT!
Offline iShine
  • Flyin'
« Reply #8 on: November 05, 2009, 08:11:19 pm »
Yes, YOU CAN'T !!!111
