Author Topic: Catalyst control center...  (Read 7216 times)
Sneaky
« on: May 01, 2011, 10:45:54 pm »
...is being gay.
When I open it I don't see all options, I've enabled advanced view but still don't see it, I've tried everything and all the options will never show no matter what I try:
http://i.imgur.com/hioNJ.png
I have completely removed the ATI drivers & software and reinstalled it and now when I open CCC it doesn't open anymore, no splash, no window, NOTHING, but the CCC.exe still shows as active in the task manager.
ATI Radeon 5770
Windows 7 64bit
Anyone have an ATI card who knows how to solve this? :(
I tried google but nothing.
Re: Catalyst control center...
« Reply #1 on: May 01, 2011, 10:52:01 pm »
ATI is gay!
http://www.overclock.net/amd-ati/892461-catalyst-control-center-no-options.html
Last Post:
OK, fixed the issue I had to uninstall again and remove incorrect GAC token from my windows folder and re-install and menus are all back.
I did my best! It took 0.22 Seconds! :D
Sneaky
« Reply #2 on: May 02, 2011, 03:58:18 pm »
I don't even know what that means, GAC token?
« Reply #3 on: May 02, 2011, 04:00:06 pm »
Well IDK either! I dont have ATI (its gay)
Thought it might help.. :(
« Reply #4 on: May 02, 2011, 05:46:39 pm »
This is an old thread, but it's one of the top search results for "ccc won't run" so I wanted to post another possible solution here. My solution was to clear out the Windows GAC (Global Assembly Cache). In Windows 7, you can browse directly to "C:\Windows\assembly". Sort by "Public Key Token", then delete everything with the Token "90ba9c70f846762e" (ATI's key). You'll obviously need Administrator privileges. No reboot needed either. Reinstalled CCC and it ran perfectly!
The GAC lets you share DLL's that are the same version number. If it's in the GAC, any installer will NOT install a new DLL - it'll use the one in the GAC. If the GAC DLL is corrupted, you're majorly SOL.
When I reinstalled the CCC, it took longer to install then it had before. Presumably, this was due to the installer copying all the correct DLL's to my hard drive. And no ATI DLL's have made it back into my GAC.
To give credit to the original poster, here's the page I found this fix on:
http://www.hardwareheaven.com/mobility-radeon-drivers-support/186707-problems-installing-catalyst-control-center.html
