Author Topic: Need some help  (Read 7503 times)
Offline j.king
Need some help
« on: June 03, 2011, 07:07:15 pm »
Ive just recently bought a pc and after getting it up and running I got this come up on my screen
First time, it came when i decided to change the desktop background so I did a force shut down and the same thing happened when i tried it again. I tried to change my desktop background once again but this time it was fine. So after a while randomly this appears on my screen again and now i cant even make it to the login screen when I start the pc.
Any Ideas?
Processor    AMD Athlonâ„¢ II X3 440 Processor
- 3.0 GHz
- 2.0 GHz HT
- 1.5MB L2 Cache
Operating System    Genuine Windows® 7 Home Premium 64-bit
RAM    - 3 GB
- DDR3
Graphics card    NVIDIA® GeForce® 6150 SE
- up to 1407 MB total available graphics memory
Screen type    None
Hard drive    500 GB, 7200 RPM, SATA
Optical disk drive    DVD-RW DL with LightScribe
Memory card reader    6-in-1
USB    6 x USB 2.0
FireWire    No
Modem/Ethernet    Ethernet 10/100
WiFi    No
Bluetooth    No
Video interface    1 x VGA
Audio interface    2 front audio ports; 3 rear analogue audio ports
TV output    1 x VGA (Analogue output)
Extension card slot    1 PCI (1 free); 2 PCI-Express 1x (2 free); 1 PCI-Express 16x (1 free)
Sound    High Definition Audio 5.1
Webcam    No
Size    Height: 426 mm
Width: 169 mm
Depth: 377 mm
Weight    9.53 kg
Re: Need some help
« Reply #1 on: June 03, 2011, 09:31:23 pm »
Video card over heating,no?
Offline j.king
Re: Need some help
« Reply #2 on: June 03, 2011, 09:39:56 pm »
what video card? its integrated atm >_>
Re: Need some help
« Reply #3 on: June 03, 2011, 09:44:27 pm »
aw that might be a problem too..
your display is probably not functional with ur GFX, try connecting ur computer on other display and see if it works..
Re: Need some help
« Reply #4 on: June 03, 2011, 09:46:53 pm »
Exactly! :P Just question..might be problem with overheating some components,fans not working well etc.,old cables,damaged connectors,shity monitor,W7 not compatible with PC or monitor or some parts aka usb,keyboard/mouse...... also might be problem with W7..tried reinstalling them or something?
Anywayz.. :o
Offline j.king
Re: Need some help
« Reply #5 on: June 03, 2011, 10:57:36 pm »
I'l take the pc down to the shop I bought it from and see what they say first
Re: Need some help
« Reply #6 on: June 03, 2011, 11:05:01 pm »
well i had a similar problem with my old graphics card.
specific particle effects caused it and i had to buy a new graphics card.
it was exactly like your problem. it got worse over time and it happened more and more often.
its most likely the graphics card, you bettar return the entire PC :)
