Author Topic: Lag  (Read 28284 times)
Offline Putty
  • Put Put...
Lag
« on: May 06, 2008, 01:48:18 am »
http://en.wikipedia.org/wiki/Lag_Switch
i was reading this and was just wondering if some thing like this could be used to give everyone the same lag???
lets Say every player has a lag of 250 <Every one has a even Lag>
then it Would be even lag Then there would be no lag in a sense  ???
if you are totally lost i tried to explain lol but if someone does understand what i meant the could you give me and answer?...
_____________________________________________________________________________________________________________________________________
Eg 30 Players have a connection range  60-100  ping
    50 players have a connection range 100-245 ping
    20 Players have a connection range 245-500 ping
what i say we could do is.
Set up a speed limiter to all players 500 ping so even if your ping is 60 your connection will be reduced to 500 ping.
limit every one to 500 thus making everyone even.
all 100 players will have a ping of 500 no one will have a lag one the other.
« Last Edit: May 06, 2008, 04:17:07 am by Putty »
<Putty> I love you too jinx.
<[eVo]twinkle> Silly putty
<Putty> ACE you love me?
<Smoke2jointS> I didn't vote
Offline [BA]iMmOrTaLiTy
Re: Lag
« Reply #1 on: May 06, 2008, 02:29:32 am »
all i can say is ''WTF'' i didnt understand ANYTHING u said...
Offline Sp4zlord
Re: Lag
« Reply #2 on: May 06, 2008, 02:37:06 am »
lolz a thing that makes a game laggier :P
ok to help you guys, ill get one of the lines:
"The basic premise behind the lag switch is to create a disturbance in the network connection causing lag"
Offline -Mattz-
  • -Stridorz-
Re: Lag
« Reply #3 on: May 06, 2008, 03:24:07 am »
If someone lags hard, the whole game/server will lag.
Re: Lag
« Reply #4 on: May 06, 2008, 03:26:02 am »
I think he means make everyone lag or something......
I dunno. Sounds like something bought through steam.
Offline Putty
  • Put Put...
Re: Lag
« Reply #5 on: May 06, 2008, 04:13:01 am »
i am not saying to use this but some thing like it to slow down some connections
Re: Lag
« Reply #6 on: May 06, 2008, 04:29:01 am »
What you're saying is:
"Do something basically impossible, or make the entire server lag like a shitpit."
That seems........................ Pointless? It doesn't help the main issue of server lag if you are lagging the server up to make it so that all players lag.... or something.
Plus, wouldn't it be SPEED UP all connections to make it less laggy instead of SLOWING DOWN connections?
Offline HoogerBooger
Re: Lag
« Reply #7 on: May 06, 2008, 09:14:32 am »
Is it just me or does LW server lag very badly lately?
Your best friend,
HoogerBooger.
Offline Putty
  • Put Put...
Re: Lag
« Reply #8 on: May 06, 2008, 11:25:30 am »
Not necessarily the theory is to give every one playing on LW's the same ping
Eg: if 1 player has a ping of 60 and another has a ping of 254 then there is lag
     But if both players has a ping of 500 there will be no lag.
     do you see where i am going with this.
Only when some one with a higher and a lower ping meet then there will be lag.
if both are equal ping then there is no lag between players....
« Last Edit: May 06, 2008, 11:31:45 am by Putty »
Offline Helicopter_boi
Re: Lag
« Reply #9 on: May 06, 2008, 12:12:48 pm »
that's a very stupid idea.
Offline Putty
  • Put Put...
Re: Lag
« Reply #10 on: May 06, 2008, 02:02:31 pm »
??? got a reason to go with that...^
Re: Lag
« Reply #11 on: May 06, 2008, 03:15:39 pm »
If you read it all, I said it is a stupid idea in simpleton terms. :P
What you are suggesting is, in a way, stupid. If everyone had the same "500 ping", which is a terribly laggy ping mind you, not only would everyone else suddenly lag like fuck, the server would have reason to lag, as that's half a second of lag time, or for the server, about 2.
^ same D:
Offline FaTaLiTy
Re: Lag
« Reply #12 on: May 06, 2008, 03:55:24 pm »
I have, you can't lead aim so suggested this? Ppl who can lead aim don't struggle fighting laggers as much, plus if we wanted to get rid of more laggy / higher pinged players the ping limiter would kick at a smaller ping (instead of 550).
Offline Putty
  • Put Put...
Re: Lag
« Reply #13 on: May 06, 2008, 04:09:15 pm »
No one understands my theory maybe Simon will...
Re: Lag
« Reply #14 on: May 06, 2008, 04:11:30 pm »
It doesn't help that you are wording it almost like one of those brazilian hacker noobs D:
help me admen pleace!
