Author Topic: Unable to join  (Read 6384 times)
Offline Rick
Unable to join
« on: July 10, 2013, 01:54:35 pm »
For some reasons i can't join when i'm using my dad's net, it will just show
I've tried reinstalling samp but that didn't slove the problem (and yes i have 0.3x).
My guess is that my ip(83.83.254.70) is rejected by the server.
I hope someone can help me with this.
Offline Popz
    • Visit me!
Re: Unable to join
« Reply #1 on: July 10, 2013, 04:33:51 pm »
Can you show the output of running "tracert 94.23.120.101" from a command line please?
Popz
Offline Rick
Re: Unable to join
« Reply #2 on: July 10, 2013, 04:38:22 pm »
Traceren van de route naar vm1.popznet.com [94.23.120.101]
via maximaal 30 hops:
  1     1 ms   <1 ms   <1 ms  192.168.178.1
  2    11 ms    11 ms     7 ms  5353FE01.cm-6-4d.dynamic.ziggo.nl [83.83.254.1]
  3    18 ms    10 ms    11 ms  amf-rc0004-ds101-vl211.core.as9143.net [213.51.1
62.33]
  4    47 ms    10 ms    11 ms  mnd-rc0001-cr101-ae12-0.core.as9143.net [213.51.
160.160]
  5    10 ms    11 ms    11 ms  asd-lc0006-cr101-ae7-0.core.as9143.net [213.51.1
58.2]
  6    14 ms     *       10 ms  amsix.routers.ovh.net [195.69.145.231]
  7    18 ms    15 ms    20 ms  rbx-g1-a9.fr.eu [94.23.122.113]
  8    26 ms     *       63 ms  vss-1b-6k.fr.eu [91.121.131.82]
  9    16 ms    15 ms    19 ms  ns366438.ovh.net [94.23.15.221]
 10    15 ms    15 ms    15 ms  vm1.popznet.com [94.23.120.101]
De trace is voltooid.
Offline Rick
Re: Unable to join
« Reply #3 on: July 12, 2013, 11:39:09 pm »
So, what now?
Offline Rick
Re: Unable to join
« Reply #4 on: August 16, 2013, 01:15:20 pm »
anyone?
Offline Nemesis
  • Leave your mark
Re: Unable to join
« Reply #5 on: August 16, 2013, 02:24:08 pm »
Get on IRC and show Popz this topic again
Offline Rick
Re: Unable to join
« Reply #6 on: August 16, 2013, 03:54:04 pm »
i did that a while ago, did it again now. I hope to get a reply now
Offline Popz
    • Visit me!
Re: Unable to join
« Reply #7 on: August 24, 2013, 08:33:13 pm »
Can you see a ping in the sa-mp browser?
Re: Unable to join
« Reply #8 on: August 25, 2013, 08:49:16 am »
Before you reinstalled it did you remove the folder in %appdata% as well? Because that can sometimes be the problem as well.
Other than that it might be that your Firewall is rejecting outgoing/incomming connections on a certain port. It could also be rejected by your Router. I for one know how bitchy Ziggo routers can be.
Though the tracert does not show any timeouts and completes its run so i find it weird as to why its not showing a connection in your SAMP browser.
Offline Rick
Re: Unable to join
« Reply #9 on: August 25, 2013, 07:54:45 pm »
I can't find a folder related to samp in %appdata% and i doubt its my firewall because i can join other servers that use port 7778.
Re: Unable to join
« Reply #10 on: August 25, 2013, 08:22:51 pm »
« Last Edit: August 25, 2013, 08:26:22 pm by EnzoMortelli »
Offline Rick
Re: Unable to join
« Reply #11 on: August 25, 2013, 08:30:22 pm »
nope
I'm not at my dad's place untill friday so i cant try anything now
Offline Rick
Re: Unable to join
« Reply #12 on: August 30, 2013, 08:57:26 pm »
Alright, anything i could try now?
Re: Unable to join
« Reply #13 on: September 06, 2013, 10:27:21 pm »
So for an update of this topic.
Ive accessed his laptop through Teamviewer and done the following.
- Ive ran a tracert on his laptop. Nothing out of the ordinary.
- Checked his firewall rules incase something was blocked.
- checked his router settings. Nothing wrong there either.
- used a clean install he had to try it out did not work either.
He is using a pre-installed version of GTA SA but i dont know if that could be related to the problem.
Other servers he sees just fine in his favorites list but LW is just not showing up. Only getting retrieving info.
Offline Rick
Re: Unable to join
« Reply #14 on: September 07, 2013, 09:55:12 am »
I found out what caused it. A long time ago i was learning to  portforward and today when i checked i noticed that i used Port Filtering. I restored it and everything works fine now.
Thanks to everyone spending their effort to help me, especially Benny.
