Read the
forum rules
before posting.
Help-Desk & Server Information
Support
Support Archive
Some help
Pages: [
Topic: Some help (Read 6107 times)
KaMRaN
VC-MP Donator
Some help
on:
April 13, 2015, 04:39:10 am »
Hello everyone!
I just bought a new Samsung LED 22 inches with 1920x1080 display. I ran the game in 1920x1080 resolution and the game was looking very amazing. But the team chat words are very small.. Please have a look:
What I'm trying to say is there any way to make font size larger than normal size? If it's possible, then how? If this can't happen in 0.3.. Shall I be able to make fonts of team chat larger in 0.4?
Last Edit: April 15, 2015, 02:38:58 pm by Darfy
Re: Some help
Reply #1 on:
April 13, 2015, 02:20:33 pm »
I dont think its possible in 0.3 but its 100% possible in 0.4 you can change many attributes such as font size, name, number of chatbox lines and probably a few others.
Darfy
Management
awards
[Ka]Darfy
Re: Some help
Reply #2 on:
April 13, 2015, 02:25:26 pm »
Not possible in 0.3, however it's possible in 0.4 along with many other kind of cosmic changes. Also as the 0.3 masterlist will be shut down next month I encourage you and everyone else who reads this to move on to 0.4.
Edit: ohh Hanney made it first
KaMRaN
VC-MP Donator
Re: Some help
Reply #3 on:
April 13, 2015, 02:40:50 pm »
Can you please tell how can I make fonts larger?
Darfy
Management
awards
[Ka]Darfy
Re: Some help
Reply #4 on:
April 13, 2015, 03:23:38 pm »
First off you've got to locate "vcmp_config.txt" and the fastest way is to do a search. After you've found it look for "con_fontscale" in the file and change the default value (1.000000) to the desired value. Set it to 1.5 for example, join a server and see how it looks.
Take a look at this topic for more info
http://forum.vicecitymultiplayer.com/index.php?topic=6009.0
Last Edit: April 13, 2015, 03:25:40 pm by Darfy
KaMRaN
VC-MP Donator
Re: Some help
Reply #5 on:
April 14, 2015, 09:06:06 am »
I put it to 1.50000 and it didn't work.. Any other idea?
Darfy
Management
awards
[Ka]Darfy
Re: Some help
Reply #6 on:
April 14, 2015, 09:45:13 am »
Let me try it out myself once i get back home from work
Darfy
Management
awards
[Ka]Darfy
Re: Some help
Reply #7 on:
April 14, 2015, 05:32:18 pm »
Works fine for myself and a few others who tried it out too. My guess is you've either somehow messed up the file while editing it or then it just somehow fails to send out the information to the client. Go to
http://forum.vc-mp.org/?board=6.0
and explain it there, maybe they can find a solution. Meanwhile double-check the config file and see that all the values are entered correctly.
Edit: I completely forgot you can edit the config while ingame too. Type /setconfig con_fontscale <value> into the chatbox. Try this.
Last Edit: April 14, 2015, 07:06:10 pm by Darfy
KaMRaN
VC-MP Donator
Re: Some help
Reply #8 on:
April 14, 2015, 08:35:11 pm »
I didn't do anything with config file.. Just tried to change font but putting another value... But I will try this while in game tomorrow morning.
Last Edit: April 15, 2015, 07:11:24 am by [UF]K.
KaMRaN
VC-MP Donator
Re: Some help
Reply #9 on:
April 15, 2015, 07:13:11 am »
Problem Solved. I used the command in game and it worked. Thanks for your kind help Darfy [:
Darfy
Management
awards
[Ka]Darfy
Re: Some help
Reply #10 on:
April 15, 2015, 02:38:50 pm »
No problem, locked.
Pages: [
Support
Support Archive
Some help
