Author Topic: FAQ about VC:MP 0.4  (Read 104189 times)
Offline stormeus
  • VC:MP Developer
FAQ about VC:MP 0.4
« on: April 14, 2015, 09:53:18 pm »
I'll try to update this post as more frequent questions get asked.
Will my stats be transferred from 0.3 to 0.4?
Transferring money, stats and vehicles is still being discussed. Donator benefits I believe are given to people who had them in LW's 0.3.
I get a message about MSVCR110.dll being missing and the game doesn't load, what do I do?
Download and install the Visual C++ 2013 redistributables:
http://www.microsoft.com/en-us/download/details.aspx?id=40784
My game crashed! WTF?
Press Windows Key + R on your keyboard, type %APPDATA%\VCMP\04beta\crashlogs and press enter. Post any crashes in the Bugs and Crashes section of http://forum.vc-mp.org, and not on the Littlewhitey's forum. Include information about what you were doing when the game crashed. Make sure to follow any additional instructions there.
There's some other bug and it's annoying.
Make a post in http://forum.vc-mp.org in the Bugs and Crashes section with information about the bug, how to produce it (if you know) and what you at least think caused it.
I have a widescreen or mouse fix ASI but it's not loading.
Use /setconfig game_allowedmods ASINAME1.asi ASINAME2.asi etc. in-game, then restart your game. ASIs are whitelisted in order to prevent mods that conflict with VC:MP 0.4 (such as VC:MP 0.3 or CLEO) from loading at the same time and causing crashes.
Why can't I spectate? Why are there no weapon pickups?
These are features that must now be implemented by servers, and are not built into every server by default.
The world is blank or empty; textures aren't appearing; players appearing without skins; buildings aren't loading.
Your game is likely running out of texture/model stream memory. If you have visual mods and used a limit increaser, your changes were overridden by VC:MP since the client has its own configuration for it. Try using /setconfig game_streammem 512 or a higher value to specify how many MB of memory should be available, then restart your game.
« Last Edit: April 15, 2015, 10:41:29 pm by stormeus »
Offline 4kUM45
  • ï»» إله إﻻ الله
Re: FAQ about VC:MP 0.4
« Reply #1 on: April 14, 2015, 09:58:33 pm »
What about ping problems? I'm getting kicked everytime for high ping, the problem is my ping went normal 90/80ms, it happens only in lw server, do you have any idea?
« Last Edit: April 14, 2015, 10:00:35 pm by 4kUM45 »
<&RastySpoon> 04** TLK.4kUM45 killed SantaClaus (M4) (Head)
<&RostySpoon> 04** TLK.4kUM45 killed Angela^ (M4) (Head)
<&RustySpoon> 04** TLK.4kUM45 killed Abdo* (M4) (Head)
<&RastySpoon> 07[4][DnA]krystianoo: oh lmao
 <&RostySpoon> 04** TLK.4kUM45 killed [DnA]Darfy (M4) (Head)
<&RastySpoon> 04** TLK.4kUM45 killed [DnA]krystianoo (M4) (Head)
 <&RustySpoon> 07* TLK.4kUM45 is on a killing spree of 10! ($1000)
<&RostySpoon> 07[15] UJIbU4: x5
<&RustySpoon> 07[1] [DnA]Darfy: not bad
Offline stormeus
  • VC:MP Developer
« Reply #2 on: April 14, 2015, 10:04:53 pm »
That might be a server bug. Can't say for sure, I'd have an admin look into that first.
Offline 4kUM45
  • ï»» إله إﻻ الله
« Reply #3 on: April 14, 2015, 10:08:08 pm »
I still don't understand why server kicks me for high ping? I'm just here to find any support from administrators about the case:
- My ping on 0.4 around 90/80ms, so I can't get kicked from the server.
- This problem happens always ONLY on lw server, I don't find any problem on other 0.4 servers.
- I was re-installing the client but I didn't found any solution about this annoying problem.
- My FPS is actually 30, maybe FPS affects on ping but I don't have a low FPS to get a high ping I thought.
Well, already posted about it but no one respondes...
Offline The Milko
  • <message removed by RajPut>
    • Dark Negative Anti-Social
« Reply #4 on: April 14, 2015, 10:56:47 pm »
I wouldn't know what's happening on your side. You'd be better off asking adtec via irc or forum pm (tho, you might no get a reply soon).
Offline AdTec_224
« Reply #5 on: April 14, 2015, 11:59:17 pm »
The ping kick system works exactly as it does in 0.3 as it is literally the same game-mode so i don't see why your having problems. The only two things i can think of are either the GetPlayerPing function in the plugin SDK isn't returning the correct data (which is unlikely as it seems to be working perfectly fine for everyone else) or it's your internet connection.
Offline 4kUM45
  • ï»» إله إﻻ الله
« Reply #6 on: April 15, 2015, 12:03:09 am »
I don't think the problem on my internet connection because, I have never been kicked for ping in lw 0.3 server, where can I find GetPlayerPing?
Offline Usmanulamin
« Reply #7 on: April 15, 2015, 09:28:32 am »
Are we going to get our 0.3 money, stats, vehicles & Donator benefits in 0.4 ?
Offline Darfy
« Reply #8 on: April 15, 2015, 02:35:58 pm »
Offline Usmanulamin
« Reply #9 on: April 15, 2015, 03:15:19 pm »
Money, Stats and vehicles must be transferred imo, otherwise it would be a huge disappointment.  :(
Offline The Milko
« Reply #10 on: April 15, 2015, 03:36:45 pm »
0.3 has different deathmatching sync and all, so stats should not be transferred.
Offline Noori
  • Give Respect Get Respect
« Reply #11 on: April 15, 2015, 05:19:59 pm »
the other day i was fighting a guy i knocked him down and blew a car near him it did some damage but did not kill him but after that he turned invisible for me until i died i could only see his shadow on the ground any idea what that might be ??
Offline Usmanulamin
« Reply #12 on: April 15, 2015, 06:26:13 pm »
Team kill drown isnt working.
Offline 4kUM45
  • ï»» إله إﻻ الله
« Reply #13 on: April 15, 2015, 08:42:17 pm »
It should be.
Offline Sorrow
« Reply #14 on: April 15, 2015, 10:40:20 pm »
And it wouldn't hurt to reset all stats, cars etc. in LW because making money is the easiest thing to do in both 0.3 and 0.4.
Regarding the ping issue, I've seen many people getting kicked for high ping, but only the players who always have had dodgy movement anyways.
Me myself went from 40 ping average in 0.3 to 15 ping average in 0.4
So I can surely say that 0.4 should decrease your ping when you have good internet, not increase it.
