Author Topic: SA-MP 0.2.2 R3 Realased!  (Read 8956 times)
« on: June 20, 2008, 10:01:44 pm »
The SA-MP 0.2.2 R3 Client has been released like an hour ago, go to http://sa-mp.com/download.php if you want to download it. It works on any 0.2.2 R2 server so you can play on littlewhitey's sa-mp server using it.
Changelog:
- Removed all SAC code. This fixes a security vulnerability mentioned earlier.
- Fixed problem with clipboard text not copying externally.
- Fixed time/fog/lighting flickering when the passing of time is disabled.
- Fixed some vehicle audio problems (silent cars/planes/boats/helis).
- Fixed texture lag/streaming popups when many models were loaded.
- Fixed some car mod shop crashes.
- Alternate siren for police vehicles is now synced.
- TextDraw code is completely rewritten. It now works in interiors and will disable with the scoreboard.
- Crashes caused by DestroyVehicle script are fixed.
- Imported some of the 0.2.5 vehicle surfing code.
- Added command /fpslimit to adjust the frame rate limiter. Valid /fpslimit values are 20-100.
« Last Edit: June 24, 2008, 04:39:15 pm by dugi »
Re: SA-MP 0.2.2 R3 Realased!
« Reply #1 on: June 20, 2008, 11:16:54 pm »
 Fixed some vehicle audio problems (silent cars/planes/boats/helis). - no more screaming monkeys under the car bug D:?
Fixed some car mod shop crashes. -  \o/
Imported some of the 0.2.5 vehicle surfing code - lol wtf
Removed all SAC code. This fixes a security vulnerability mentioned earlier - FUCK YOU JACOB YOU USELESS GEEK  8)
well all in all it looks good..gonna install it now :D
edit: first i get this, i went to retry loads, then abort...that didn't do anything, so i restarted installation and just did ignore....
then i'm asked if the program installed correctly or if i wanted windows to reinstall with the correct settings, i said it installed correctly, how can i find out if it did install properly?
« Last Edit: June 21, 2008, 01:38:00 pm by THEWICKERMAN D: »
« Reply #2 on: June 22, 2008, 12:56:17 am »
I've created a vehicle surfing video, you can see it here: http://www.youtube.com/watch?v=JvrdCtKeijY
Offline Neonkiller
  • Got Milk?
« Reply #3 on: June 22, 2008, 05:55:15 am »
Its not as great as 2.5.5 would have been but it did make it smoother to ride on fluffy :D and the other vechs COOL \o/
Btw some bugs have come up with R3 like seeing someone getting jacked but there still in the car and a sound bug where a vech is empty but still makes some noise but still its still cool
connect to a server and it would say 2.2 R3 has started up and bla bla bla in yellow text that should tell u that its installed
« Reply #4 on: June 28, 2008, 11:44:49 pm »
Thanks for this version, building look fine, not popping up. I love it. Thank you!
« Reply #5 on: June 29, 2008, 08:36:28 am »
wha?
i still fly into invisible buildings. :x
Offline Enzo03
« Reply #6 on: June 29, 2008, 09:17:08 pm »
I get more spells of FPS lag that last longer on this version... I may consider switching back to R2...
I do enjoy that this version is more stable, however, and the time between FPS spells is ***usually*** long.
