Author Topic: a bug or what?  (Read 4402 times)
Offline Azure
  • VUholic
a bug or what?
« on: February 10, 2016, 03:10:10 pm »
hey whenever I connect to lw server its says logged in etc.. but doesn't load and when I send a message it says not connected to a server but it works fine with other servers please find out whats the problem
« Last Edit: February 21, 2016, 02:19:20 pm by Darfy »
Re: a bug or what?
« Reply #1 on: February 10, 2016, 03:33:34 pm »
I also get this problem  1 or 2 month ago this problem caused because  i was installed a network which changed my IPv4 and IPv6 settings then i was bought i new card ( I thought my Lan card problem ) but  still it not working then i Re window my pc then its works correctly. Maybe you install a new client or what  you installed that changed your IPv4 and IPv6 Setting try to restore files by firewell if not work then  search on google you find some help there if you cant search then Re window your PC.
Offline Azure
  • VUholic
Re: a bug or what?
« Reply #2 on: February 10, 2016, 03:37:28 pm »
thanks for the help smd :)
Offline Darfy
Re: a bug or what?
« Reply #3 on: February 21, 2016, 02:19:10 pm »
Solved, moved to archive.
