Author Topic: HELP! I CAN'T FIX IT!!  (Read 8636 times)
Offline VCTaxiDriver
  • SA-MP: VCTaxiDriver
  • VC-MP: VCTaxiDriver
« on: March 06, 2016, 01:30:44 pm »
I got a PROBLEM when I CONNECT TO LITTLEWHITEYS!
It said "FALIED TO LOAD CUSTOM WAEPON WEAPONS/W105_S3_|18_DESERTEAGLE.7Z - INVALID WEAPON DATA"
Then I had being disconnected from the server  :-\
Please tell me how can I fix this  :'( :'(
PLEASE!!  :'( :'( :'(
« Last Edit: March 06, 2016, 01:43:27 pm by VCTaxiDriver »
                                  https://imgflip.com/gif/1u2og3
Re: HELP! I CAN'T FIX IT!!
« Reply #1 on: March 06, 2016, 02:23:13 pm »
 Still don't works :'( :'( :'(
« Last Edit: March 06, 2016, 02:28:31 pm by VCTaxiDriver »
« Reply #2 on: March 06, 2016, 02:26:56 pm »
« Reply #3 on: March 06, 2016, 03:49:28 pm »
 I have that DLL file but it still don't works :(
And I am not the user of Kaspersky :(
What can I do then :'(
« Last Edit: March 06, 2016, 03:54:44 pm by VCTaxiDriver »
Offline iKitKat
  • Have a break, Have a KitKat
  • SA-MP: iKitKat
« Reply #4 on: March 07, 2016, 12:59:10 am »
Uninstall VCMP, maybe its a update error, also delete everything that is relationated to VCMP
That can help
Offline stormeus
  • VC:MP Developer
« Reply #5 on: March 07, 2016, 02:06:48 am »
Go to C:\Users\YOUR_USERNAME\AppData\Roaming\VCMP\04beta and open the debuglog.txt file. Paste it into a post here, between [code][/code] tags.
« Reply #6 on: March 07, 2016, 11:16:45 am »
MSG: Blocked plugin 'cleo.asi', ASI mods are not allowed in VC:MP
MSG: Blocked plugin 'vc-mp.flt', ASI mods are not allowed in VC:MP
MSG: Successfully loaded San Andreas vehicle texture dictionary.
MSG: Wave file gunshot.wav - using channel 0 for both left and right samples.
MSG: Successfully loaded weapon 100 from file unknown
MSG: Successfully loaded weapon 101 from file unknown
MSG: Successfully loaded weapon 102 from file unknown
MSG: Wave file gunshot.wav - using channels 0 and 1 as left and right samples.
MSG: Successfully loaded weapon 103 from file unknown
MSG: Successfully loaded weapon 104 from file unknown
Error in CMvlWeapon::LoadModelFile: Loading clump from DFF file failed.
Error in CMvlWeapon::LoadFromArchive: Loading weapon model file failed.
Error in CWeaponHandler::LoadWeaponArchives: Could not load weapon archive 'weapons/w105_s3_l18_deserteagle.7z'.
Offline stormeus
  • VC:MP Developer
« Reply #7 on: March 08, 2016, 07:34:00 am »
Interesting. Typically people fail to load textures but you're actually failing to load the model itself. I can tell you've modified your game because VC:MP is trying to load a CLEO ASI. Are you trying to inject ASIs? Have you tried playing on a clean copy of VC:MP?
« Reply #8 on: March 08, 2016, 11:30:09 am »
I tried to play on a clean copy but still failed to load that model  :'(
Can you send me those custom files :'(
Maybe those files were damaged during download  :'(
Offline WannaCry
  • Heart touching virus
    • https://en.wikipedia.org/wiki/WannaCry_ransomware_attack
  • SA-MP: WanaCrypt
« Reply #9 on: March 08, 2016, 06:50:20 pm »
U copied some mods to gta vc folder
So i suggest to delete and reinstall gta vc
« Reply #10 on: March 10, 2016, 02:26:07 pm »
I deleted everything and tried to reinstall everything
But still failed to load the .dff and the model
What should I do then  :'(
Please help me fix this  :'(
« Reply #11 on: March 10, 2016, 03:01:40 pm »
Delete your VC  again then press Windows key + R then type"regedit"(Without comas) then press ok after this in  registry  you find this key name"HKEY_LOCAL_MACHINE" click on it then click on "Software" then Rockstar Games hope you find GTA VC register there delete it then restart you PC then Install gta vc(You must need restart your PC)
  Hope this will work.
Edit:   C:\Documents and Settings\YOURUSERNAME\AppData\VCMP\04beta\store\91.121.134.5-8192\weapons  (change that weapons file name which error you received name like desert_eagle.7z but don't change the .7z and then join server then check the server auto rename  that file or not) I hope you will connect to the server.
  If not work then i will try to make a video of it.
« Last Edit: March 10, 2016, 03:22:47 pm by [RK]SMD_ASSHOLE »
« Reply #12 on: March 28, 2016, 03:05:49 pm »
Still fail to load that dff  :(
Error in RpClumpStreamRead: Reading FRAMELIST failed.
Error in RpClumpBufferReadWithDict: RpClump is null.
« Reply #13 on: March 28, 2016, 03:45:20 pm »
Turn off your Firewall  and Windows defender then check it.
« Reply #14 on: March 28, 2016, 05:21:15 pm »
reinstall windows.
