Author Topic: admen  (Read 12062 times)
Offline Maddy`
  • ÃŒl Mìgìlòrè
  • SA-MP: Maddy
admen
« on: April 06, 2016, 11:01:34 am »
I got back from about 2 months of break. To start playing VCMP again, when I got in lw's, it downloaded a few files, and then this popped up and I was disconnected.
« Last Edit: April 13, 2016, 09:09:30 pm by Darfy »
Offline BeaTz
Re: admen
« Reply #1 on: April 06, 2016, 12:25:05 pm »
You no allow to play
Credits :
Disney
Hanney Ur dad me
Re: admen
« Reply #2 on: April 06, 2016, 12:38:01 pm »
If you have Kaspersky or another anti virus/firewall check this topic:
http://forum.littlewhiteys.co.uk/index.php/topic,24702.0.html
Offline Maddy`
  • ÃŒl Mìgìlòrè
  • SA-MP: Maddy
Re: admen
« Reply #3 on: April 06, 2016, 04:10:57 pm »
It's only the Desert Eagle, the rest are working fine, I went into other servers which had the new weapons except this particular one. Any solutions for this?
Re: admen
« Reply #4 on: April 06, 2016, 05:38:28 pm »
No particular solution that I can think of. In this case if all the other weapons work I don't see why the desert eagle doesn't...
Offline The Milko
  • <message removed by RajPut>
    • Dark Negative Anti-Social
Re: admen
« Reply #5 on: April 06, 2016, 08:40:26 pm »
Sorry, but I don't know the solution. I'm pretty sure someone does, though.
Offline krystianoo1
Re: admen
« Reply #6 on: April 06, 2016, 08:57:29 pm »
%appdata% > VCMP > 04beta > store > 91.121.134.5-8192 (lw's ip) > weapons > remove archive with deserteagle and enter the server again
Kelvin Garcia Mendoza
Re: admen
« Reply #7 on: April 07, 2016, 01:04:43 am »
I would say REMOVED These new weapons added to the server, to be avoiding conflicts with players. There may come a new player to the server and pass the same as Maddy and not knowing what to do.
I say remove these weapons.
Offline NikY.Wolf / ValaK
  • SA-MP: [CO]NikY.Wolf
Re: admen
« Reply #8 on: April 07, 2016, 01:30:45 am »
-999
can fix bugs without remove new weps
Offline Maddy`
  • ÃŒl Mìgìlòrè
  • SA-MP: Maddy
Re: admen
« Reply #9 on: April 07, 2016, 08:04:48 am »
Still doesn't work, Apparently, VCTaxiDriver and I are facing the same problem
http://forum.littlewhiteys.co.uk/index.php/topic,24652.0.html
« Last Edit: April 07, 2016, 08:09:04 am by Maddy` »
Offline Maddy`
  • ÃŒl Mìgìlòrè
  • SA-MP: Maddy
Re: admen
« Reply #10 on: April 07, 2016, 09:08:28 am »
Tried re-installing VC and VCMP, when I downloaded VCMP, my Windows Defender took action on the download and detected a Virus, maybe thats it.
Disabled Windows Defender, still ain't working.
PS: I got no anti-virus.
« Last Edit: April 07, 2016, 09:22:43 am by Maddy` »
Re: admen
« Reply #11 on: April 07, 2016, 08:27:32 pm »
I've no idea what could be causing this it's very strange.
Offline The Milko
Re: admen
« Reply #12 on: April 08, 2016, 01:30:50 am »
Me neither....
Re: admen
« Reply #13 on: April 08, 2016, 01:38:57 am »
I just don't get why the other weapons load file but this one doesn't... invalid weapon data? I'm guessing it means its something up with reading the .xml but ehh...
Check here for a debuglog.txt and paste it's contents maybe theirs something inside that's more specific to the problem.
C:\Users\USERNAME\AppData\Roaming\VCMP\04beta
I guess this is a better suited topic for the vc-mp forum though.
Offline Maddy`
  • ÃŒl Mìgìlòrè
  • SA-MP: Maddy
Re: admen
« Reply #14 on: April 08, 2016, 04:40:57 am »
MSG: Successfully loaded San Andreas vehicle texture dictionary.
MSG: Wave file gunshot.wav - using channel 0 for both left and right samples.
MSG: Successfully loaded weapon 100 from file unknown
MSG: Successfully loaded weapon 101 from file unknown
MSG: Successfully loaded weapon 102 from file unknown
MSG: Wave file gunshot.wav - using channels 0 and 1 as left and right samples.
MSG: Successfully loaded weapon 103 from file unknown
MSG: Successfully loaded weapon 104 from file unknown
Error in RpClumpStreamRead: Reading FRAMELIST failed.
Error in RpClumpBufferReadWithDict: RpClump is null.
Error in CMvlWeapon::LoadModelFile: Loading clump from DFF file failed.
Error in CMvlWeapon::LoadFromArchive: Loading weapon model file failed.
Error in CWeaponHandler::LoadWeaponArchives: Could not load weapon archive 'weapons/w105_s3_l18_deserteagle.7z'.
