Author Topic: Again happened!! Lost Money 800k+!!  (Read 3501 times)
Offline iamKANEKi
  • Pakistan Zindabad
« on: June 05, 2016, 02:39:13 pm »
GentleMan , i applied for new-nick two weeks ago, no admin accepted and i became hopeless and made new account ingame , i gave my friend money and he gave me back from new account and now i lost them after reconnect.
[18:09:09]  You have received $6 from [CF]Raid3n^!
[18:09:09]  [CF]Raid3n^: !give killer 6
[18:09:14]  You have received $100000 from [CF]Raid3n^!
[18:09:14]  [CF]Raid3n^: !give killer 100000
[18:09:14]  *> NaWghty_Boy connected. <*
[18:09:14]  *** NaWghty_Boy is connecting from Pakistan.
[18:09:15]  *> =CF=Rami^ killed Federal with an M4 to right arm. <*
[18:09:15]  You have received $100000 from [CF]Raid3n^!
[18:09:15]  [CF]Raid3n^: !give killer 100000
[18:09:16]  Auto-muted:[ [CF]Raid3n^ ] Duration:[ 30 seconds ]
[18:09:16]  You have received $100000 from [CF]Raid3n^!
[18:09:16]  [CF]Raid3n^: !give killer 100000
[18:09:20]  *> =CF=Rami^ killed ldgjkfjgd with a SPAS shotgun to right leg. <*
[18:09:24]  [CFt]KillerKid: thannkx
[18:09:28]  NaWghty_Boy: !give 0 100000
[18:09:29]  =CF=Rami^: boboboobbobobobobo
[18:09:34]  *> [CFt]A2z^ killed RdmzNN. with a shotgun to torso. <*
[18:09:38]  RdmzNN.: yar full side the na?
[18:09:39]  NaWghty_Boy: 1min full
[18:09:39]  =TRC=Tarkan: you better sit
[18:09:43]  Report cheaters/hackers on our forum: http://littlewhiteys.co.uk
[18:09:48]  [THUG]Ghotsrider: hacia el aeropuerto
[18:09:50]  *> =CF=Rami^ killed THEvcmp with an M4 to head. <*
[18:09:51]  Auto-kicked:[ aadil ] Reason:[ Ping average exceeded 500ms ]
[18:09:51]  *> aadil disconnected (kicked). <*
[18:09:51]  RdmzNN.: me takr?
[18:09:54]  *> ldgjkfjgd exploded. <*
[18:09:57]  You have received $100000 from [CF]Raid3n^!
[18:09:57]  [CF]Raid3n^: !give killer 100000
[18:09:59]  You have received $100000 from [CF]Raid3n^!
[18:09:59]  [CF]Raid3n^: !give killer 100000
[18:09:59]  *> MoNsTeR* connected. <*
[18:09:59]  *** MoNsTeR* is connecting from Pakistan.
[18:10:03]  *> RdmzNN. killed [CFt]A2z^ with a shotgun to left leg. <*
[18:10:03]  You have received $100000 from [CF]Raid3n^!
[18:10:03]  [CF]Raid3n^: !give killer 100000
[18:10:04]  *> =CF=Rami^ killed THEvcmp with a SPAS shotgun to right leg. <*
[18:10:04]  * =CF=Rami^ is on a killing spree of 5! ($500)
[18:10:06]  RdmzNN.: :P
[18:10:07]  *> Zayon disconnected. <*
[18:10:08]  You have received $100000 from [CF]Raid3n^!
[18:10:08]  [CF]Raid3n^: !give killer 100000
[18:10:08]  Auto-kicked:[ NaWghty_Boy ] Reason:[ Ping average exceeded 500ms ]
[18:10:08]  *> NaWghty_Boy disconnected (kicked). <*
[18:10:10]  *> =CF=Rami^ killed ldgjkfjgd with an M4 to head. <*
[18:10:11]  You have received $100000 from [CF]Raid3n^!
[18:10:11]  [CF]Raid3n^: !give killer 100000
[18:10:13]  RdmzNN.: !fix
[18:10:18]  *> =CF=Rami^ killed THEvcmp with an M4 to head. <*
[18:10:20]  [CFt]KillerKid: thnakx
[18:10:21]  You have received $15000 from [CF]Raid3n^!
[18:10:21]  [CF]Raid3n^: !give killer 15000
[18:10:27]  [CF]Raid3n^: sahe he ?? pore ho gaye na ?
then after reconnect :
[18:37:17]  Connecting to 91.121.134.5:8192..
[18:37:20]  Connection success. Loading server info...
[18:37:22]  *> [CFt]KillerKid connected. <*
[18:37:22]  Welcome to littlewhitey's v2.1! (C++)
[18:37:22]  *** [CFt]KillerKid is connecting from Pakistan.
[18:37:22]  >> You are now logged into your PAC account (PAC:36144).
[18:37:22]  >> http://community.project-apollo.co.uk
[18:37:22]  >> Any name changes can be done via the community website, this will automatically transfer your stats etc..
[18:37:25]  You are currently holding:[ $500 ]
[18:37:25]  You currently have:[ $0 ] in your bank.
[18:37:25]  [CFt]KillerKid: !money
Offline krystianoo1
Re: Again happened!! Lost Money 800k+!!
« Reply #1 on: June 05, 2016, 02:41:12 pm »
PAC saves player data once the player rejoins after registering.
So if I create a new acc called 'xxx', /register it without leaving and transfer 300 k using !givecash xxx 100000 3 times and rejoin the game, the money will be gone. If I /register, rejoin, and then !givecash it will be saved.
On the other hand, if I register 'xxx', leave the game, go to PAC and transfer my account to xxx the transfer won't work. Both accounts will be gone because you can't transfer to an already-existing account.
« Reply #2 on: June 05, 2016, 02:53:25 pm »
Uh, didn't this exact thing already happen before? I remember giving you refunded money the last time you lost it. I don't have access to name approvals either to see if your name is somehow their waiting to be approved.
Which was the new nickname you tried to change your account to?
Have you tried to contact any admins on IRC/forum regarding it?
Why did you not post a thread like this asking whats up and why your name hasn't been changed despite it being 2 weeks ago?
Offline iamKANEKi
  • Pakistan Zindabad
« Reply #3 on: June 05, 2016, 04:46:24 pm »
I dont know why nick not changed , infect i forgot for the nick i applied.
Nope.
I forgotten that i applied for nick because i was also inactive , and today im accepted in CF clan and i logged in my pac account and applied for new nick then it says that already pending request.
« Reply #4 on: June 05, 2016, 10:15:19 pm »
Well, you should have contacted an admin directly regarding the delay as now theirs a huge unneeded mess happening as you went ahead and done your own thing. You remember this exact problem happened last time? And I said it's been too long ago when you tried to provide me screenshots/logs etc of the evidence of the money existing. Since you kept going on and on I refunded you your money from my own account. Afterwards, I also told you not to do this again in future and to use the proper name change method? You've just done the exact same thing I told you not to do. Your money won't be refunded  as you never took the advice I gave you back then and we're in the exact same mess as before with an even larger amount of money than last time.
