Author Topic: [DIDN'T KNOW WHICH BOARD TO POST IN]Just a small help  (Read 11159 times)
Offline Pizza
« on: August 26, 2016, 07:11:49 pm »
Well, today I've tried to join on the SA-MP server and as you can see clearly in the screen-shot below that I got the "gta_sa.exe has stoppd working" message. This error usually appears on older versions of samp server and I've that version installed due to my modifications. But this is SA-MP 0.3.7 and all the other server I do play work normally. Thanks in advance!
Jayce
Re: [DIDN'T KNOW WHICH BOARD TO POST IN]Just a small help
« Reply #1 on: August 26, 2016, 07:25:42 pm »
This should be in Technical Support board, anyways, I don't think your issue is from SA-MP, but it's from GTA SA itself. Try reinstalling GTA SA which might fix the problem.
« Last Edit: August 26, 2016, 07:27:56 pm by Jayce »
Offline Pizza
« Reply #3 on: August 27, 2016, 09:57:56 am »
Well, I'd be thankful if you send me GTA-SA download link.
Jayce
« Reply #4 on: August 27, 2016, 10:01:30 am »
I can't send it to you through forums, because it isn't allowed to discuss, nor share cracked material. I'd send it to you through PM if that's allowed.
« Last Edit: August 27, 2016, 10:04:30 am by Jayce »
