Author Topic: zeodex  (Read 3703 times)
Offline essex
zeodex
« on: February 12, 2017, 07:01:43 pm »
Nick used whilst ingame: zeodex
Time and Date that you were banned: 4 days ago
Suspected Reason (if any): speed hacks tools etc etc
IP Address: pm
PAC ID: 39998
Admin that banned you (if known): Hanney
Extra notes: So is simple;
I got ban for no reason, because my fast switch is too faster for any of you, i also have proofs that my ping spike without doin nothing, neither enabling hacks or any other shit https://youtu.be/q3TiZ_VBGbc
i dont download, neither enabled hacks.. i only have a method to keep my mouse in my hand, i cant tell it bcause is a secret (if really needs, i can via pm)
i dont see why hanney ban me, there is no kind of hack, modification or any shit, just my ping spike because i got a router with micro sim, which i cant mantein a stable connection.. if need i can record my gameplay = + desktop to show you that im not hacking..
EDIT: with this method of keeping my mouse in hand i do a faster fs
« Last Edit: February 12, 2017, 07:26:55 pm by essex »
Re: zeodex
« Reply #1 on: February 12, 2017, 07:33:07 pm »
You were banned for speed hacks / modification of game weapons.
There is only so "fast" that a players movement can be after doing a fast switch and moving from A to B which is mechnically defined by the game itself as there is a forced waiting period of about 400ms before the fast switch happens (unless crouch glitch was used to skip that). Your increase in player acceleration from standing still moving from point A to B can't just be explained by ping spikes alone.
As for the video you posted it's irrelevant as a form of evidence to make a proper judgement on. Firstly it's not littlewhiteys and you could do whatever you wanted at that point ie control ping or whatever just for the purposes of recording. Regardless a ping jumping 100-200ms wouldn't cause ping spikes or effect a players movement all that bad. It would require a much larger jump than that with alot of packetloss and ontop of that it would be clearly evident in all of your movements... If your connection was so bad your running would be very warpy in general and your weapon accuracy would also suffer very badly which does not seem to be the case in the evidence posted to us. I've been playing this mod since it first came out in 2005 (older versions) and playing 0.4 but not once have I ever seen any sudden warp when fast switching on a consistent basis like submitted in the video to us as. It must be just a big coincedence how those "warps" only occur when you fast switch and not any other time from what we seen. A number of the staff from the vc-mp team had a private discussion about this case and we all came to the conclusion that something is definetley up here in terms of whether it's a speedhack/modified weapon data we have had years of experience and a gut instinct that something is clearly not right here and it's not just a connection problem as I've explained above.
EDIT: Show us a video of your method and we'll see if we can relate it somehow to what was seen in the video recorded of you.
« Last Edit: February 12, 2017, 07:34:44 pm by Hanney »
Offline essex
Re: zeodex
« Reply #2 on: February 13, 2017, 07:09:56 am »
I will when im at home
EDIT: http://imgur.com/a/2LoDf
Method used to switch weapon
« Last Edit: February 14, 2017, 04:46:14 pm by essex »
Offline KaraN.
Re: zeodex
« Reply #3 on: February 14, 2017, 06:37:57 pm »
XDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
sorry i couldn't resist commenting here..
Re: zeodex
« Reply #4 on: February 14, 2017, 06:53:48 pm »
I thought you were gonna make a video to show how your method is faster, to explain the sudden bursts of speed in movements.  But all this diagram tells me is which buttons you use for fast switching (which is the most common way by default controls from what you have shown) What is right click used for in this case?
« Last Edit: February 14, 2017, 07:02:35 pm by Hanney »
Offline essex
Re: zeodex
« Reply #5 on: February 14, 2017, 08:24:23 pm »
Im using the middle sometimes for the right click, the video isnt a problem but im not at home, i will come back next week
Offline essex
Re: zeodex
« Reply #6 on: February 19, 2017, 11:21:33 am »
